Can the PanelDue SD card slot run the entire machine?
Just wondering if I could use the External PanelDue SD card slot for the Duet and not use the onboard slot at all?
Just thinking this could be useful if there was something wrong with the onboard slot or just for convenience.
Not without changing the firmware, default firmware will only look at the internal slot for config.g and /www at least
The SD card on the PanelDue also runs slower than the on board one.
