External bearings for stepper shafts
@Nxt-1 yeah it is ~1mm, but if you can flip the pulley you get a nice, big contact surface.
For my application this is enough and it was the only way to fit it in without doing a major redesign to my printer. It is a heavy modified Hypercube Evolution, 10mm belt and gates pulley and roles. -
If you're breaking motor shafts or destroying motor bearings, you probably have the belt tension set too high.
If you're wearing out 3D printer idler pulleys with 3 mm or even 5 mm bore, I think it's to be expected. Compare the size of the bearings in those pulleys to the size of the bearings in the motor. The tiny balls in the bearings that are small enough to fit in those pulleys put a LOT of pressure on the races and wear either the races or the balls out. If you use stacked ball bearings for pulleys, you can use bearings with much larger diameter balls (like those in the motor) and get much longer operating life because the contact pressure is lower (same force from belt tension, but larger area of contact). They take up more space, but they typically don't cost much more than the 3D printer pulleys and they last a lot longer.
@mrehorstdmd gday could you share the stl file for this thank you terence
@terence Are you asking for the servo motor mount with the extra bearing? I used Fusion360 to design it specifically for the 45 mm t-slot I am using in the sand table. STL files are attached, but you might prefer the Fusion360 file so you can modify it easily to fit your t-slot...
The motor mounts are embedded in the sand table Fusion360 design file that you can DL here.
NEMA-17_servo_motor_mount_A.stl
NEMA-17_servo_motor_mount_B.stl
The motor mounts were designed using my "standard technique"- start with a model of the motor, pulley, bearing, and screws, add a solid block and carve away just enough plastic to fit the motors, belts, and other hardware. It results in a very chunky, solid mount that won't flex (much) under belt tension.
I did not end up using the extra bearing in the sand table motor mounts because one of the motors has a bit of runout in the shaft (I know, but how are you going to return it to China?) and it got pretty noisy with the extra bearing.
