configuring Dual Z w/ Dual Z endstops....
final RR3 config
config.g
M569 P4 S0 ; physical drive 4 goes backwards
M584 X0 Y2 Z1:4 E3 ; set drive mapping
M350 X16 Y16 Z16:16 E16 I1 ; configure microstepping with interpolation
M92 X80.00 Y80.00 Z800.00:800.00 E420.00 ; set steps per mm
M566 X900.00 Y900.00 Z12.00:12.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X6000.00 Y6000.00 Z180.00:180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z20.00:20.00 E250.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800:800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeoutM671 X0:250 Y0:250 S0.5 ; leadscrews at left (connected to Z) and right (connected to E1) of X axis
M208 X0:250 Y0:250 ; X carriage moves from -5 to 205, Y bed goes from 0 to 200; Axis Limits
M208 X350 Y350 Z850 S0 ; set axis maxima; Endstops
M574 X1 S0 P"xstop" ; configure active-low endstop for low end on X via pin xstop
M574 Y1 S0 P"zstop" ; configure active-low endstop for low end on Y via pin zstop
;M574 Z1 S0 P"ystop" ; configure active-low endstop for low end on Z via pin ystop
M574 Z1 S0 P"ystop+e1stop" ; configure active-low endstop for low end on Z via pin ystopbed.g
; bed.g
; generated by RepRapFirmware Configuration Tool v2.1.5 on Fri Jan 10 2020 16:18:31 GMT+0700 (Indochina Time)
G29 ; probe the bed and enable compensation
G28 ; home
;M401 ; deploy Z probe (omit if using bltouch)
G30 P0 X250 Y250 Z-99999 ; probe near a leadscrew, half way along Y axis
G30 P1 X250 Y250 Z-99999 S2 ; probe near a leadscrew and calibrate 2 motors
;M402 ; retract probe (omit if using bltouch) -
did you try homing?
@Veti not yet, waiting for a print to finish before i reflash to 3.x
@Veti Okay so it doesnt home Z the way i would think. 1 end stop per Z axis .... cut the motor per side when end stop triggered. the right (Y) Z end stop both from movement, where i would think the opposite side would continue to move until its end stop was triggered.
config.g
M569 P0 S0 ; physical drive 0 goes forwards
M569 P2 S1 ; physical drive 2 goes backwards
M569 P1 S1 ; physical drive 1 goes backwards
M569 P3 S0 ; physical drive 3 goes forwards
M569 P4 S1 ; physical drive 4 goes backwards
M574 Z1 S0 P"ystop+e1stop" ; configure active-low endstop for low end on Z via pin ystop; Z-Probe
M558 P1 C"zprobe.in+zprobe.mod" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:195 S20 ; define mesh gridbed.g
; bed.g
G28 ; home
this has to be answerd by dc
