heater faults while printing
the actual temperature can not drop instantly by 50 degrees.
there might be a loose connection or something else wrong with your thermistor. -
@Veti Thanks, I just switched H2 over to H1 thermistor to see if maybe it had a loose connection as you describe. So far it's heating up alright. Very well could be a bad wiring job on my connections.
It will fault just sitting, I think the fault during movement was a coincidence
