XYZ carriage rise without reason
@Veti said in XYZ carriage rise without reason:
do you have a config-overwrite? because you have a M501 in your config.
I'm not sure if it's useful. I had enabled it along with the ability to save the print in the event of a blackout.
please post the config where it was working.
checking it I saw that:
M563 P0 D0 H1 F0in my CR10 file config D0 is not there.
I don't know why the online configurator doesn't create it.
can it be the cause? I haven't had time to try yet.
yes
If there is no 'D' field the tool has no drives. -
yes
If there is no 'D' field the tool has no drives.ok! sorry for the delay but I checked only now.
the problem was just that "D" missing.
now everything works as it should.Thanks for your help.
