Maestro ethernet has stopped working
So weird issue, my Maestro was working fine. But today I started it up and couldn't get to the web interface. The IP I'd set also wasn't on the network. After some poking around I found the Ethernet port on the Duet is flashing green intermittently, but the port on the switch is just solid orange. I took the known working cable off my other printers Pi and tried on that and same result. Don't really know where to go from here. Any thoughts?
The green flashing LED on the ethernet port is normal.
Have you tried to connect to it using USB?
https://duet3d.dozuki.com/Wiki/What_to_do_if_your_Duet_won't_respondHTH.
Paul.
