Inverting PS_ON levels
@insertnamehere said in Inverting PS_ON levels:
@nxt-1 +5V is from the Meanwell aux supply.
I'm sorry to dig up this old thread, but I finally can to actually using this schematic. According to the datasheet, the 24V PSU needs: "RC+/RC- : 4 ~10V or open = power on ; 0 ~ 0.8V or short = power off" as a remote control signal. I soldered the little circuit together, but when I connect +5V and GND to the two terminals of my 5V PSU and measure the RC+ output of this diagram, I measure just 3.3V to GND. Also did you leave RC- floating or tied to GND in your printer?
While thinkering with the optocouper, I came to think if there is any good reason to not connect the transistor straight across the RC+ and RC- terminals? As I see it, this would create a short or open based on PS_ON controlling the PSU just as well as a voltage applied. If I am mistaken, please correct me
@nxt-1 said in Inverting PS_ON levels:
Yes, I think this is the way to go.
Could someone check if RC- is the same as GND of the output?
@fma said in Inverting PS_ON levels:
I measure 193mV between RC- and V- of my HPRG200-24.
I had the same problem and solved it with a simple 7400 NAND gate chip: https://forum.duet3d.com/topic/412/inverting-ps_on
So, you wired RC- to GROUND?
@tomasf said in Inverting PS_ON levels:
Mind sketching up a quick diagram?
I tried it, but I forgot the signal needed to be inverted. As a result, this way it is functional but reversed. I not proficient enough with electronics to know if there is anything I can do to fix this, with the stuff I got laying around.
This post is deleted! -
Sorry, I've not been online to answer earlier.
I leave RC- open and just connect to the RC+ input.
Are you using the 5V aux from the Meanwell or a separate 5V supply? -
Hmmm.... let me check.
TO TURN ON SUPPLY.
Duet PS_ON goes to ground to turn on power. PS_ON ground will turn on the opto diode.
Opto diode on will cause the transistor to go ~ short. Short on Meanwell RC+ to RC- will turn OFF the Meanwell supply.If you connect emitter/collector of the opto across the RC+ and RC- of the supply this will not invert the PS_ON signal. That is why the emitter resistor is needed.
This will not invert the PS_ON signal. The PS_ON signal from the Duet is a "Ground = On" and the Meanwell is "Open = On". The Emitter resistor inverts the signal.
Yes, you're right. You need to use @jv43 config, using 5V from Meanwell. So this only works for this power supply. If the 5V is from another source, and this source turns off, the Meanwell remains ON
Are you using the 5V aux from the Meanwell or a separate 5V supply?I am using a separate 5V Meanwell supply.
The other 5V supply is permanently on.
TO TURN ON SUPPLY.
I tried the schematic you posted for your HFG600, that supply needs 2 ~ 5V or Open circuit to power on. In this case the ~3.3V I measured from your circuit is perfect. The HPRG I use needs 4 ~ 10V, to turn on, making the 3.3V insufficient. That is why my earlier test failed I believe.
Did you connect GND of both power supplies?
I did not wire a connection from 5V- to 24V- terminals, however in both supplies the negative rail is connected to ground (mains ground that is) and those are of course wired up. So in a way there is a GND path between both PSU.
https://www.meanwell.com/webapp/product/search.aspx?prod=HRPG-200
https://www.meanwell.com/webapp/product/search.aspx?prod=RS-25 -
I got myself a couple of 74HC00's to plat with. I assume you you wired your system like this? What value did you use for the pull up?
Hy, I have an Meanwell PSPA-1000-24 and removed the bridge from the power supply. Then I connected the contacts "Ground" and "PS_on" to the power supply and connect an small 5V power supply (Jumper 5V ext!). If you switch the ATX-Power on (M80) the "PS_on" is connected to the "Ground".
It works fine!
@sw said in Inverting PS_ON levels:
PSPA-1000-24
A quick glance at your PSU's datasheet shows that it's RC logic is inverted compared to most Meanwell's, thus making it directly compatible with the Duet.
