IR Probing Issue always showing values around 990 to 1000
I had a problem with my ir probe; always showing values around 990 to 1000. Initially i was convinced, the fault might not be from wiring. Since, I was using professional tools and also I was getting a red light trigger when I go close to the sensor, then after checking the continuity with multimeter showed that the continuity of the Z probe_in is open. After rewiring the P value shows 0. Going to do the homing by Z probe, hopefully this should work.
