PT 100 not working
i just switched to rtd2 to see if that would help but no.
that looks to be fine to me only thing I can think is that you may either have a faulty port in which case you could try RTD2 and change to X201 or you have wired it up incorrectly it is hard to tell (and very easy to get wrong) if you use the same colour wiring.
It looks like you have taken four wires to the sensor so you need to check that pins 1 and 2 are a pair and 3 and 4 are the other pair.
other than those 2 ideas I am not sure what to suggest
@dougal1957 Perhaps a faulty PT100 sensor or daughter board.
@brian possible I guess but I would try the other channel first
@dougal1957 done that
next step I guess is to get a 100 ohm resistor to check the daughter board ports!
@dougal1957 where am i going to get that?
check the resistance of your pt100 with a multimeter
ok thanks
