Anycubic Linear Duet 3d extruder still running too fast
So I've set cura to absolute (as using 2.4.0) in the slicer settings and also in config.g It does seem to have slowed it down a bit but it's still running fast causing skipping as the extruder can't keep up.
Look at this video I took
any idea why this is happening, it seems to be running to quick. could it be hardware, or do you think software. Here's my slicer staat code and then my config.g
G21 ;metric values
G90 ;absolute positioning
M107 ;start with the fan off
G28 ;move to endstops
M82
G92 E0 ;zero the extruded length
G1 F200 E3 ;extrude 3mm of feed stock
G92 E0 ;zero the extruded length again
G1 F{travel_speed}
;Put printing message on LCD screen
M117 Printing...here's my config.g
M82 ; ...but absolute extruder moves;*** The homed height is deliberately set too high in the following - you will adjust it during calibration.
M665 R136 L288.15 B120 H217 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; Put your endstop adjustments here, or let auto calibration find them; Network
M550 PMy printer ; Set machine name
M552 S1 ; Enable network
M587 S"GoogleWifi" P"EMMETT24" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M92 X80 Y80 Z80 E663 ; Set steps per mm
M566 X1200 Y1200 Z1200 E1200 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000 Y18000 Z18000 E1200 ; Set maximum speeds (mm/min)
M201 X1000 Y1000 Z1000 E1000 ; Set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; Set motor currents (mA) and motor idle factor in per cent
M208 Z0 S1 ; Set minimum Z; Endstops
M574 X2 Y2 Z2 S1 ; Set active high endstops; Z-Probe
M558 P5 R0.4 H5 F1200 T6000 ; Set Z probe type to effector and the dive height + speeds
G31 P100 X0 Y0 Z-0.211 ; Set Z probe trigger value, offset and trigger height
M557 R120 S20 ; Define mesh grid; Heaters
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1
M143 H1 S280 ; Set temperature limit for heater 1 to 280C; Fans
M106 P0 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P1 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Tools
M563 P0 D0 H1 ; Define tool 0
M501
; Automatic saving after power loss is not enabled; Custom settings are not configured
Please help, I'm losing my patience
@sparkymark79 said in Anycubic Linear Duet 3d extruder still running too fast:
663
Where did you get your steps/mm value for the extruder from? If you got it from another firmware then was that firmware using the same microstepping?
A Google search for anycubic linear configuration returns the following page:
https://github.com/SpainLabs/Anycubic-kossel-3d-printer/blob/master/Configuration.h
which has the following line:
#define DEFAULT_AXIS_STEPS_PER_UNIT { 80, 80, 80, 96 }
I'm not suggesting you just blindly copy this figure but there is a massive variation. That extruder looks to be ungeared which, again, is suggestive of a low steps/mm figure being correct. The documentation has a section on ungeared extruders here:
https://duet3d.dozuki.com/Wiki/Choosing_an_extruder_drive#Section_Un_geared_extruders
which suggests values of around 100.
Hope this helps.
adavidm
ah ok, this is interesting
so this lin here:
am i right in thinking my extruder is set to 663 steps per mm?
it should be more like 96?
thanks for your help
That's right. Apologies, I had intended to copy and paste the whole line, not just the number!
You should get somewhere in the right region with 96. I'd still recommend you fine-tune the extruder after doing that though. There are loads of tutorials on how to do that, including Thomas Sanladerer's here:
https://toms3d.org/2014/04/06/3d-printing-guides-calibrating-your-extruder/
On the Duet, you can send an M92 command while the printer is running. e.g.
M92 E96
and you can see the results straight away. Use a guide like Tom's to get the figure as accurate as possible, then modify your config.g with the new value.
adavidm
