Web Interface - Fan Control Settings
If I change the settings to show Fan 2 and Fan 3 in the interface panel settings and click 'apply ' they appear in the print status panel but next time I open the Web Interface they disappear.
Is there any way to make the changes permanent?Web Interface Version 1.21 - Firmware Version 1.21
Thanks
The change should be permanent when you hit Apply Settings. Try clearing the browser cache.
@deckingman said in Web Interface - Fan Control Settings:
Edit (Unless you've discovered a bug in the latest firmware - I'm on a slightly older version)
If I try to clear the cache I get a 'no entry' sign on the button. Other changes I have made such as notification time out and half z steps stay permanently.
