Error after upgrade to 1.21
I upgraded my 3 printers to 1.21 and all work perfectly except the DuetWiFi on my duplicator 6. Ever since the upgrade and I try to home X, Y, or all I get an error:
"G28 X
Error: G0/G1: insufficient axes homed:"Now I get this error when I try home X. I was able to determine the problem has to do with the Z-Axis as my macro for homex essentially lowers the bed by 5 homes x and then raises z again. I believe I left it the waG91 ; relative positioning
[[language]] G1 Z5 F6000 ; lift Z relative to current position G1 S1 Y-205 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 Y5 F6000 ; go back a few mm G1 S1 Y-205 F360 ; move slowly to Y axis endstop once more (second pass) G1 Z-5 F6000 ; lower Z again G90 ; absolute positioningy the configurator created. Anyways, when I comment out the Z-Axis commands it works fine.
You need to add S2 parameter to lines where Z axis are moved. That should fix the problem
[[language]] G1 Z5 F6000 S2 ; lift Z relative to current position ```and
[[language]]
G1 Z-5 F6000 S2 ; lower Z again -
Yup, that did it. Thanks!
