Core XY - pulling my hair our.
Number of issues....
- Running like a snail...only 10mms on X homing attempt
- Sensor less homing is not working. When it get to 0 it hammers the carriage and then tries to do a Z drop . given it shared motors that makes sense I guess
Motors are 1.8 LDO motors
I have attached my config.g and homez.g
Any help appreciated please
Ray
What type of printer do you have as in make? ,
has it been working before?
have you made any chages? -
@Kiwi3D is your steps/mm correct, move the x axis 20 mm does it move 20mm?
G'day ...yes...that part is perfect
Thought the below video might explain my issue better
@Kiwi3D up your homing speed to F8000 ,
here is my x homing, your need to change out my motors numbers for yours
; homex.g echo "home the X axis" M400 ; make sure everything has stopped before we make changes G91 ; relative positioning M915 P0:1 S5 H200 F0 R0 ; Configure Stall Detection M906 X550 Y550 ; set homing motor current G1 F8000 G1 H1 X-350 ; Home X-Axis independently M906 X1000 Y1000 ; set homing motor current M915 P0:1 S35 H500 F0 R1 ; Configure Stall Detection M400 ; make sure everything has stopped before we make changes G90 ; absolute positioning G1 F12000 X152.5
@moth4017
You're Core XY too? -
@Kiwi3D im core XY , , you are core Xz
but you should still be able to use my home x , you need to modify it for your core XZsomething like this
; homex.g echo "home the X axis" M400 ; make sure everything has stopped before we make changes G91 ; relative positioning M915 P0.0 S5 H200 F0 R0 ; Configure Stall Detection M906 X550 ; set homing motor current G1 F8000 G1 H1 X-350 ; Home X-Axis independently M906 X1000 ; set homing motor current M915 P0.0 S35 H500 F0 R1 ; Configure Stall Detection M400 ; make sure everything has stopped before we make changes G90 ; absolute positioning G1 F12000 X152.5
