How to connect PSU for Neopixel and signal wire
When using an external PSU for led strip how is it supposed to be connected?
If +/- of the LED PSU goes directly to LED strip will it work connecting the single LED strip signal wire to a Mini5 board LED parts signal pin?
In my limited knowlege of these things I would think thar the duet board need at last two wire to send a signal. Like signal.and ground, so the pixies/electrons has somewhre to go... 🥴
@fotomas wire it as you said and connect the negative of the LED PSU to the negative of the printer PSU
@jay_s_uk I
do not want to argue but then then power to the LED strip is just one lead. It will only join on the AC side. I do not understand...ahhh negative to negative between the PSU'sBut I have an answer how to connect things, thank you!
@fotomas thats the one. +ve +-ve of LEDs to LED PSU. LED PSU -ve to -ve of printer PSU. Neopixel control from the duet to the LEDs
@jay_s_uk
Is it ok to connect to LED strip in parallel? Would it work and both behave the same, as a mirror image of eachother?
