RRF Compatible Stealthburner CAN-FD board finally released
I am pleased to announce that RRF finally has a compatible Stealthburner CAN-FD board. https://s.click.aliexpress.com/e/_DdqyPGN
There are two versions that are compatible with RRF (and as a bonus are also compatible with klipper), the SB2040 Max v3 and the SB2040 Pro Max v3.The SB2040 Max v3 has the following main features
TMC2209 driver
LIS2DW onboard accelerometer
Onboard LC1612 for Z Scanning Probe support. This is the same as the Duet3D SZP. It is also compatible with Duet3D scanning probe heads.
MAX31865 onboard for PT100 support.
The SB2040 Pro Max v3 swaps the TMC2209 for a TMC2240.
Documentation will be on the teamgloomy wiki in the coming days.
Is there a CAD file of the tollboard? I would like to install two pieces in my IDEX printer. Thanks
@Proschi78 they can be found here https://mellow.klipper.cn/#/board/fly_sb2040_v3_pro/3dmodel
@jay_s_uk If I want to use a Duet 3 Tool Distribution Board, would there be a problem?
@Proschi78 I can't see any reason for it to be an issue
