Hotend fan nor working.... :?
Hi *
I'm a bit confused about a new problem with my IDEX printer. The hotend cooling fan for one of the two toolheads (T1) is not working and I do not understand why. I measure 1.9V when the fan should spin. The fan is connected to 122.out.2 on the 2nd toolboard (1LV v.1.0).
; Head 1 (left) ; Tune in with: M303 H1 S270 ; M308 S1 P"121.temp0" Y"thermistor" T500000 B4702 C1.171057e-7 ; configure sensor 1 as thermistor on pin temp1 Revo M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 2 as thermistor on pin temp1 Revo M950 H1 C"121.out0" T1 ; create nozzle heater output on out1 and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S310 ; set temperature limit for heater 1 to 280C ; Head 2 (right) ; Tune in with: M303 H2 S270 ; M308 S2 P"122.temp0" Y"thermistor" T500000 B4702 C1.171057e-7 ; configure sensor 2 as thermistor on pin temp1 Slice M308 S2 P"122.temp0" Y"thermistor" T100000 B4725 C7.060000e-8 ; configure sensor 2 as thermistor on pin temp1 Revo M950 H2 C"122.out0" T2 ; create nozzle heater output on out1 and map it to sensor 1 M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H2 S310 ; set temperature limit for heater 1 to 280C ;; Fans ; Fan for the printed part left: M950 F0 C"121.out1" Q500 ; create fan 0 on pin 121.out1 and set its frequency M106 P0 S0 H-1 C"Part L" ; set fan 0 value. Thermostatic control is turned off ; Fan for the left hotend M950 F1 C"121.out2" L0:1000 Q50 ; create fan 1 on pin 121.out2 and set its frequency M106 P1 S1 H1 T45 C"Hotend L" ; set fan 1 value. Thermostatic control is turned on ; Fan for the printed part right: M950 F2 L0:1000 C"122.out1" Q50 ; create fan 2 on pin 122.out1 and set its frequency M106 P2 S0 H-1 C"Part R" ; set fan 2 value. Thermostatic control is turned on ; Fan for the right hotend M950 F3 C"122.out2" Q500 ; create fan 3 on pin 122.out2 and set its frequency M106 P3 S1 H2 T45 C"Hotend R" ; set fan 3 value. Thermostatic control is turned on P=No. S=Speed H=ThermostaticMode ;; Tools ; Tool 0 aka "the left wing" X M563 P0 S"L" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Filament sensor : Status M591 D0 M591 D0 P5 C"121.io1.in" R230:360 E3.0 S0 ; S1 = Enabled S0 = Disabled ; Tool 1 aka "the right wing" U M563 P1 S"R" D1 H2 F3 X3 ; define tool 1 P=No. S=Name D=Extruder H=Heater F=Fan X=Mapping to X ;G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets ;G10 P1 R0 S0; set initial tool 1 active and standby temperatures to 0C G10 P1 Y0 U0 Z0 S0 R0 ; set tool 1 offsets and temperatures ; Filament sensor M591 D1 P5 C"122.io1.in" R230:360 E3.0 S0 ; S0 = Disabled
Anybody an idea where my typo is? (The fan for the left toolheat (T0) is working.)
Firmware: RepRapFirmware for Duet 3 Mini 5+ 3.5.0-rc.3 (2024-01-24)
Duet WiFi Server Version: 2.1beta7Cheers, Chriss
@Chriss how did you measure the voltage? VIN to the PWMยดd ground or to some static ground like at the power connector?
I would at first make try to configre the fan as a normally controlled fan and see if I can spin it up using M106. If that does not work, I would check my wiring (power to the board, wiring to the fan).
@oliof I measured with my oscilloscope, lust to make sure that I do not confuse any multimeter with the pulses.
The toolboard "works" as expected, the heater the thermistor etc. But you are right I should simplify the setup first. I will check the fan on a other output first too. I may have a user error with my scope too.
We we agree that the software config is not totally wrong, isn't it?
Chreers, Chriss
@Chriss you probably could drop the L parameters for the fan definitions, but other than that as far as I was able to compare with my IDEX config it looks alright. So if there is something utterly wrong, we both missed it.
@oliof You are right... Don't know why that L is in the config to be honest. I think that because of the tacho wire the fans have and I tried to make use of it. The config is 2+ years old, I can not explain everything. the M950s should be the same anyway. I will do that but I guess that it will not change anything.
I need to solve a other problem with the printer, so I will to the analysis later/tomorrow.... Thanks for the input!
Cheers, Chriss
I played with the toolboard a bit today. I have the 12V when I measure between GND from out.1 and +12 from out.2. The fan starts to spin when I put a jumper wire between GND from out.1 and out.2. I have the feeling that I have fried the FED on be toolboard.
Need to look a bit at the docu to find find the FED and have a look at it. -
I found it.... I had a other Fan3 which is my LED stripe, so there was a collision in the config.
@Chriss glad you got this sorted! I missed the LED as well.
