BIQU Microprobe with 6HC.
BIQU Microprobe with 6HC. Good afternoon, I am replacing my BLtouch with a BIQU Microprobe. I recently did the same thing a while back on my other DIY printer and had great help here. I tried to use similar code, but I am running into issues. I am I think it may be the firmware versions as I am using the newer firmware on my new printer. The probe triggers on startup 3 times like normal. When I go to home the probe moves to the center of the bed and the probe deploys and the bed starts to move up, but the probe triggers before the bed even gets close and I get a M42 error code. Does anyone know what I am missing? I have my BL touch code commented out.
Thanks,
Justin; Configuration file for RepRapFirmware on Duet 3 Main Board 6HC ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2 on Sat Dec 30 2023 14:39:37 GMT-0600 (Central Standard Time) ; General M550 P"Duet 3" ; set hostname ; Network M552 P0.0.0.0 S1 ; configure Ethernet adapter M586 P0 S1 ; configure HTTP M552 I1 S1 ; Smart Drivers M569 P0.0 S0 D3 V2000 ; driver 0.0 goes forwards (X axis) M569 P0.1 S1 D3 V2000 ; driver 0.1 goes backwards (Y axis) M569 P0.2 S0 D3 V2000 ; driver 0.2 goes forwards (Z axis) M569 P0.3 S0 D3 V2000 ; driver 0.3 goes forwards (Z2 axis) M569 P0.4 S0 D3 V2000 ; driver 0.4 goes forwards (Y2 axis) M569 P0.5 S0 D3 V2000 ; driver 0.5 goes backwards (extruder 0) ; Motor Idle Current Reduction M906 I30 ; set motor current idle factor M84 S30 ; set motor current idle timeout ; Axes M584 X0.0 Y0.1:0.4 Z0.2:0.3 ; set axis mapping M350 X16 Y16 Z16 U16 V16 I1 ; configure microstepping with interpolation M906 X1000 Y1000 Z1000 ; set axis driver currents M92 X80 Y80 Z400 ; configure steps per mm M208 X0:275 Y0:275 Z0:275 ; set minimum and maximum axis limits M566 X900 Y900 Z12 ; set maximum instantaneous speed changes (mm/min) M203 X6000 Y6000 Z180 ; set maximum speeds (mm/min) M201 X500 Y500 Z20 ; set accelerations (mm/s^2) ; Extruders M584 E0.5 ; set extruder mapping M350 E16 I1 ; configure microstepping with interpolation M906 E1000 ; set extruder driver currents M92 E420 ; configure steps per mm M566 E120 ; set maximum instantaneous speed changes (mm/min) M203 E3600 ; set maximum speeds (mm/min) M201 E250 ; set accelerations (mm/s^2) ; Kinematics M669 K0 ; configure Cartesian kinematics ; Probes ;M558 K0 P9 C"io4.in" H5 F120 T6000 ; configure BLTouch probe via slot #0 ;G31 P500 X0 Y0 Z1.78 ; set Z probe trigger value, offset and trigger height ;M950 S0 C"^io4.out" ; create servo #0 for BLtouch ; Microprobe M558 K0 P5 C"io4.in" H3 F60 T6000 A10 R1.25 S0.008 B1 ; Set Z probe type/mode 9. H=Dive Height. F=Speed probe speed, G31 P500 X0 Y0 Z1.78 ; set Z probe trigger value, offset and trigger height M950 S0 C"^io4.out" ; create servo/gpio 0 on heater 3 on expansion connector ; Endstops M574 X1 P"!io0.in" S1 ; configure X axis endstop M574 Y1 P"!io1.in" S1 ; configure Y axis endstop ;M574 Z1 P"!io3.in" S1 ; configure Z axis endstop M574 Z1 S2 ; configure Z axis endstop ; Mesh Bed Compensation M557 X20:200 Y20:200 S20:20 ; define grid for mesh bed compensation ; Sensors M308 S0 P"temp0" Y"thermistor" A"Heated Bed" T100000 B4725 C7.06e-8 ; configure sensor #0 M308 S1 P"temp1" Y"thermistor" A"Nozzle" T100000 B4725 C7.06e-8 ; configure sensor #1 ; Heaters M950 H0 C"out0" T0 ; create heater #0 M143 H0 P0 T0 C0 S140 A0 ; configure heater monitor #0 for heater #0 M307 H0 R0.268 K0.299:0.000 D4.39 E1.35 S1.00 B0 ; configure model of heater #0 M950 H1 C"out1" T1 ; create heater #1 M143 H1 P0 T1 C0 S285 A0 ; configure heater monitor #0 for heater #1 M307 H1 R2.43 D5.5 E1.35 K0.56 B0 ; configure model of heater #1 ; Heated beds M140 P0 H0 ; configure heated bed #0 ; Fans M950 F0 C"out5" ; create fan #0 M106 P0 S0 L0 X1 B0.1 ; configure fan #0 M950 F1 C"out4" Q500 ; create fan #1 ;M106 P1 S0 H1 T45 ; configure fan #1 M106 P1 S0 B0.1 H1 T45 ; configure fan #1 ; Tools M563 P0 D0 H1 F1 ; create tool #0 M568 P0 R0 S0 ; set initial tool #0 active and standby temperatures to 0C
; deployprobe.g ; called to deploy a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2 on Sat Dec 30 2023 14:39:41 GMT-0600 (Central Standard Time) ;M280 P0 S10 ; deploy BLTouch M42 P0 S1
; retractprobe.g ; called to retract a physical Z probe ; ; generated by RepRapFirmware Configuration Tool v3.5.0-rc.2 on Sat Dec 30 2023 14:39:41 GMT-0600 (Central Standard Time) ;M280 P0 S90 ; retract BLTouch M42 P0 S0
@yagodajm your M950 is wrong for the probe. You're creating a servo output with the S0 but you should be using P0 instead as the output for a microprobe isn't a servo
@jay_s_uk Ok, I changed S0 to P0 and I am still getting the same error. Any other ideas?
Thanks,
Justin -
@yagodajm is it a v1 or v2 microprobe?
@yagodajm V2. I got it, I have to invert the pin.
M558 K0 P5 C"^!io4.in" H3 F60 T6000 A10 R1.25 S0.008 B1 ; Set Z probe type/mode 9. H=Dive Height. F=Speed probe speed,
Thanks,
Justin -
