Talos IDEX Large Format 3D Printers by Project R3D
Project R3D has recently released our new line of Talos printers. The Talos is designed to be a feature-packed large-format printer aimed to be a workhorse for many industries. With build volumes ranging from 600x600x600mm up to 600x1800x600mm you can print full automotive body panels all at once.
Find out more at https://www.projectr3d.com/
IDEX is standard on all Talos units, allowing for several different print configurations. Support removal and post-processing of the part can be a major hassle when working with such large parts, having a dedicated support material allows for effortless removal and minimal cleanup. Speed is always a factor in additive, but with such large build volumes, speed is even more critical. Running a high-detail nozzle for small details or walls and then having a large nozzle for supports and infill can drastically reduce print time.
When it comes to speed, the Talos has it. Rapids in X,U, and Y are limited to 1000mm/sec. The only thing holding you back will be your hotends volumetric flow rate.We offer the Talos assembled or as sub-assemblies for those who can't fit an assembled unit into their shop.
We offer the Hemera Revo, Bondtech LGX/Mosquito Magnum, and Bondtech LGX/Mosquito Magnum+.
When we set out to design the Talos, we wanted to accomplish a couple of things, we are glad to say we did!
- Duet3 ecosystem of electronics to allow for expansion and upgrades
- Fastest printers in the category
- Feature packed, make competitors options standard in the Talos (IDEX, Linear Rails, Casters)
- Best price in the category
- Robust build quality
- Assembled
- Sub-assembly kit allowing for 2 hour assembly time, rather than 4-7 days with competition
- Highest Quality Components
- Camera assisted calibration
