Cannot upgrading firmware from 2.05.1 to 3.0 and 3.4.5
@genioluiz7 said in Cannot upgrading firmware from 2.05.1 to 3.0 and 3.4.5:
SD card 0 not detected, interface speed: 20.0MBytes/sec
do you have the SD card in the board when you ran this?
Can you also confirm what filesystem the SD card has been formatted in? (it should be FAT32 to work) -
@jay_s_uk no the SD card was in my pc when I run M122. Do I retry the command with the SD card inside?
The SD card is formatted correctly
@genioluiz7 yes, would just help to make sure its being read correctly
@jay_s_uk === Diagnostics ===
RepRapFirmware for Duet 2 WiFi/Ethernet version 2.05.1 running on Duet WiFi 1.02 or later
Board ID: 0JD0M-9P6M2-NW4SN-6J1DG-3SD6J-TUT3L
Used output buffers: 1 of 24 (11 max)
Static ram: 25712
Dynamic ram: 93140 of which 0 recycled
Exception stack ram used: 320
Never used ram: 11900
Tasks: NETWORK(ready,1416) HEAT(blocked,1232) MAIN(running,3736) IDLE(ready,160)
Owned mutexes:
Last reset 00:14:53 ago, cause: power up
Last software reset time unknown, reason: User, spinning module GCodes, available RAM 11732 bytes (slot 1)
Error status: 0
Free file entries: 10
MCU temperature: min 28.8, current 32.6, max 32.9
Supply voltage: min 1.5, current 1.7, max 24.4, under voltage events: 1, over voltage events: 0, power good: no
Cache data hit count 2698876049
Slowest loop: 1.71ms; fastest: 0.05ms
Hiccups: 0, FreeDm: 160, MinFreeDm: 160, MaxWait: 0ms
=== DDARing ===
Heater 2 is on, I-accum = 0.0
Segments left: 0
Movement lock held by null
http is idle in state(s) 0
telnet is idle in state(s) 0
file is idle in state(s) 0
serial is ready with "M122" in state(s) 0
aux is idle in state(s) 0
daemon is idle in state(s) 0
queue is idle in state(s) 0
Code queue is empty.
=== Network ===
Slowest loop: 200.45ms; fastest: 0.06ms
HTTP sessions: 0 of 8- WiFi -
Network state is running
Failed messages: pending 0, notready 0, noresp 1
WiFi firmware version 1.27
WiFi MAC address 84:0d:8e:b3:04:69
WiFi Vcc 3.40, reset reason Turned on by main processor
WiFi flash size 4194304, free heap 25800
WiFi IP address 192.168.1.53
WiFi signal strength -56dBm, reconnections 0, sleep mode unknown
ok
- WiFi -
@genioluiz7 so thats fine. does it still show as
Duet ejected your HTTP request
when you navigate to 192.168.1.53? -
@jay_s_uk said in Cannot upgrading firmware from 2.05.1 to 3.0 and 3.4.5:
192.168.1.53
@genioluiz7 ok, i see the issue.
replace the contents of the www folder with the contents of this zip file https://github.com/Duet3D/RepRapFirmware/releases/download/2.05/DuetWebControl-SD-2.04.zip -
@jay_s_uk
Just to specify... Have I to unzip this file and put all the files inside in the www folder? -
@genioluiz7 yep
@jay_s_uk ok now? retry M122?
@genioluiz7 now try the ip address again (obviously with the SD card inserted and the board power cycled)
@jay_s_uk again
@genioluiz7 my only other thought is that you're running the latest wifi firmware with 2.05.1.
put this file https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2CombinedFirmware.bin
and this file https://github.com/Duet3D/RepRapFirmware/releases/download/3.0/Duet2CombinedIAP.bin
in the "sys" folder thats on the SD card.
Then with the sd card inserted sendM997
using YAT
that should install 3.0. you can then confirm using M115
then try browsing to the IP address again -
@droftarts I've already tried this
@jay_s_uk
So, have I just to put them in the sys folder? -
@genioluiz7 yep, then run M997 etc
@jay_s_uk M997
M997: Firmware binary "Duet2CombinedFirmware.bin" not found
ok -
@genioluiz7 and thats with the SD card installed in the board? that sounds slightly more concerning.
SendM39
and post the output -
@jay_s_uk M39
M39: No SD card mounted in slot 0
ok
Is it inserted on the right side? -
@genioluiz7 its orientated correctly but it should be inserted a lot deeper than that
