Layer fan does not work during printing
google traslate:
Hello I have a problem I revived my cartesian machine after more than 1 year, and update from version 2.5 to 3.4.5. After having changed some new things that it brings and a week of investigating why the layer fan works with the slider of the DWC, but at the time of printing it does not activate.
Probe with gcodes from the previous week that I printed with the old version and with the new one not active.
I pass my settings to see if anyone gives a hand thank you!!!!. from Argentina:
PS: I also have this error: Error: Heater 0 fault: Heater 0 fault: temperature rising too slowly: expected 2.29°C/sec measured 0.65°C/sec. that I am investigating, if I heat it to 5 degrees, it does not mark the error. But it is a separate issue. Thank youHola tengo un problema reviví mi maquina cartesiana luego de mas de 1 año, y actualice de la version 2.5 a la 3.4.5. luego de haber cambiado alguna cosas nuevas que trae y una semana de investigar el por que el ventilador de capa funciona con el control deslizable del dwc, pero a la hora de imprimir no activa.
probe con gcodes de la semana anterior que imprimí con la version vieja y con la nueva no activa.
paso mi configuración a ver si alguno ne da una mano mil gracias!!!!. desde Argentina:
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.16 on Sun Jun 11 2023 20:22:41 GMT-0300 (hora estándar de Argentina); General preferences
M550 P"SERGIO2" ; set printer name
;M564 S1 H0
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P1 s1 ; physical drive 1 goes forwards
M569 P3 S1 ; physical drive 3 goes backwards
M92 X100 Y100 Z400 E410:410 ; set steps per mm
M208 X-15 Y-15 Z0 S1 ; set axis minima
M208 X300 Y300 Z200 S0 ; set axis maxima; Endstops
M574 X1 S1 P"!xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"!ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S1 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater3" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z3.25 ; set Z probe trigger value, offset and trigger height
M557 X15:270 Y15:270 S20 ; define mesh grid; Heaters
M143 H0 S90 ; set temperature limit for heater 0 to 90C
M308 S1 P"e1temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp
M950 H1 C"e1heat" T1 ; create nozzle heater output on e1heat and map it to sensor 1
M143 H1 S240 ; set temperature limit for heater 1 to 240C; Fans
M106 P0 C"VENT CAPA" S0 H-1 ; set fan 0 value. Thermostatic control is turned off
M106 P1 C"VENT HOTEND" S0 H1 T45 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 D0 H1 F-1 ; define tool 0
T0
; Custom settings are not defined -
@silvasergio15 you need to map the layer fan to the tool in M563. It should be F0 and not F-1 like you have
@jay_s_uk un millon de gracias , era una cosa facil, pero se escapo a mi entender. gracias!!!!!!!!.. gracias!
A million thanks, it was an easy thing, but it escaped my understanding. Thank you!!!!!!!!.. Thank you!
Solucionado funciona correctamente!! -
