VSSA Thermistor 2 fault
I have been modifying a printer with a Duet 2 board. On boot up the Bed Heater connected to E1 is showing a temp of -271 degrees.
The E0 hot end heater is showing the correct ambient temp.If I swap the two thermistor plugs Bed Heat reads ambient on E0 and Hot end faults to -271 on E1.
This suggests that there is a board fault with E1 despite the fact that a close visual inspection doesn't show any physical damage
I presume that I can connect the bed thermistor to any one of the 5 spare thermistor pins 35 - 39 on the expansion socket. As there is only one pin for each of those five spare spots, I presume the other thermistor lead is connected to ground? -
@Pierre52 Doh. Problem solved when i connected the bed Thermistor to the correct plug beside the bed heater.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
