Non Duet Hardware with RRF ?
This post is deleted! -
@Herve_Smith awesome thanks for this, just ordered a set
@Herve_Smith which sensor have you used and is that a spring?
@Herve_Smith that's them ordered too. many thanks
@Herve_Smith Are you able to share your files?
@Herve_Smith I have this experimental one which mounts the 1LC in the flap, leaves just enough room to allow for the chain and exposes the two buttons which I have programmed to extrude/retract
@pixelpieper do you share your cad files somewhere?
@Herve_Smith where can I find the stl file for this stealthburner duet 1LC cover? Would love to do the same.
@pixelpieper
Are there any news on your project or is it possible to continue working on it (if you may share the files)?
I really like your approach and want to use is for my Voron Switchwire.
