Decrease in X and Y movement speeds after resuming a print
Hello evryone,
When i resume a print after pause, the x and y moves speeds ares decrease.
Do you know if a setting can do this on my config ?
Thanks
Rodrigue -
@Rodrigue-Richalland The most likely cause is that your pause and/or resume macros will have a G1 Xn Yn Fn command to move the print head. The Fn will be the feedrate which will override whatever feedrate you initially set in your slicer, and will persist until a new "Fn" parameter s sent. So you need to restore that feedrate in your resume macro to match whatever you used in your slicer.
@deckingman Thanks you so much for your help. I've fix my issue
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
