Emergency Push Button Pin Wiring
Hi I am planning to install a Emergency Push Button to the IO Connector of Duet 3D Mainboard 6HC.
The Push Button has three wires 1. NO (Normally Open) Wire 2. NC Wire 3. C Wire
To what Pins should these wires be connected to Duet 3 IO Pin's?
I am attaching the Specification Sheet and Wiring Photo of this Emergency Push Button for Reference
@jay_s_uk Hi Thanks for the reply
Inference that NC Wire should be Connected to the GND Pin on the IO Connector. And the C and NO to which on the IO Connector to be connected? -
Since the next question will likely be 'what do I put into my config.g file?', this is my section for the emergency switch that I just installed after having procrastinated waay too long and having killed some expensive hardware. I am connected to the io7 port between ground and io7.in. It doesn't matter which wire goes to which of those two pins:
; Set up EMERGENCY STOP button
M950 J1 C"IO7.in" ;creat input pin number 1 (J1) which is connected to the input of io7 connector
M581 P1 T0 C0 S0 ; configure input pin number 1 (P1) .... T0 = emergency stop on trigger, C0 = allow trigger at any time (not just during print), S0 triggers on falling edge (NC)My emergency switch/button locks in the activated position. I have to twist it to let it pop back out to the 'run' position. Note that DWC gives you a message saying something about resetting the machine. You have to click on that message after the emergency stop is released in order to restart things.
@weed2all Thanks for the Reply
@jay_s_uk Thanks
@jens55 Thanks for the Support
