High hotend position just on the first print
Very wired issue, yes i know.
On the first print of the day, my print home all axis and begin to print really high above the bed, offset with Z Babystepping makes no changes at all. Do not use auto bed level.
After stop this first one and send the same file again everything goes normal.
Any tips on how to solve this wired one?
I will post below the details that i think can be helpful:
Ender 3 pro
Electronics
Board: biquskr_rrf_e3_1.1 (STMWiFi)
Firmware: RepRapFirmware for STM32F4 based Boards 3.4.0_1 (2022-03-17)
Duet WiFi Server Version: 1.26-05S-Dconfig.g
; Configuration file for SKR-RFF-E3-v1.1 (firmware version 3)
; generated by RepRapFirmware Configuration Tool v3.3.1-LPC-STM32+7 on Sun May 08 2022 13:24:01 GMT-0300 (Horário Padrão de Brasília); General preferences
M550 P"Ender3" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards using TMC2209 driver timings
M569 P1 S0 ; physical drive 1 goes backwards using TMC2209 driver timings
M569 P2 S1 ; physical drive 2 goes forwards using TMC2209 driver timings
M569 P3 S0 ; physical drive 3 goes forwards using TMC2209 driver timings
M92 X80.00 Y80.00 Z400.00 E96.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z60.00 E360.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z1800.00 E6000.00 ; set maximum speeds (mm/min)
M201 X500.00 Y500.00 Z100.00 E5000.00 ; set accelerations (mm/s^2)
M906 X800 Y800 Z800 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X225 Y225 Z250 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Z via pin zstop; Z-Probe
; M558 P0 H5 F120 T6000 ; disable Z probe but set dive height, probe speed and travel speed
; M557 X15:215 Y15:195 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp
M950 H0 C"bed" T0 ; create bed heater output on bed and map it to sensor 0
M307 H0 R0.309 K0.367:0.000 D0.86 E1.35 S1.00 B0
; M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
M143 H0 S120 ; set temperature limit for heater 0 to 120CM308 S1 P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp
M307 H1 R2.641 K0.594:0.000 D6.20 E1.35 S1.00 B0 V24.0 ; PID Tune
; M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H1 S260 ; set temperature limit for heater 1 to 260C; Fans
M106 P0 C"Part Cooling Fan" S0 H-1 ; set fan 0 name and value. Thermostatic control is turned off
M106 P1 C"Hotend Fan" S1 H-1 ; set fan 1 name and value. Thermostatic control is turned off; Tools
G31 Z-0.5
;Ender Original LCD
M918 P1 E4 F1000000; Custom settings are not defined
homeall.g
; called to home all axes
G91 ; relative positioning
G1 H1 X-230 Y-230 F1800 ; move quickly to X and Y axis endstops and stop there (first pass)
G1 H2 X5 Y5 F6000 ; go back a few mm
G1 H1 X-230 Y-230 F360 ; move slowly to X and Y axis endstops once more (second pass)
G1 H1 Z-255 F800 ; move Z down until the endstop is triggered
G1 H2 Z5 F600 ; go back a few mm
G1 H2 Z-10 F200 ; lower Z again
G90 ; absolute positioning; Uncomment the following lines to lift Z after probing
;G91 ; relative positioning
;G90 ; absolute positioninghomez.g
; called to home the Z axis
; generated by RepRapFirmware Configuration Tool v3.3.1-LPC-STM32+7 on Sun May 08 2022 13:24:02 GMT-0300 (Horário Padrão de Brasília)
G90 ; absolute positioning -
@joaomedina In your homeall.g and homez.g
I believe should be H1 not H2... H1 is for homing H2 is individual motor move
I don't know if that will fix your issue, if not, maybe try adding a start.g file (it will automatically runs at the start of your print) and have it home Z again.
@wwak84 Thanks for your reply!
Just had a small problem with my micro SD and build the RRF from scratch again. The issue is solved, sadly we will never know what cause it.
@joaomedina Small problem with the micro sd indeed! Glad its working.
undefined Phaedrux has marked this topic as solved
