Height Map Padding
@norder it's an issue for @Sindarius as I mentioned previously as he programmed the height map plugin
@jay_s_uk I rewrote the 3D component of the heightmap plugin which replaced ThreeJS to BabylonJS which is used for the G-Code Viewer. It does come down to adjusting how the controls layout and resize in code.
@sindarius said in Height Map Padding:
Is that something you are able to change, or is it in the DWC code?
@ccs86 It has to be changed in the plugin which is bundled with DWC.
Is it something user editable, like a config file?
If not, would you be willing to push an update?
@ccs86 Not user editable unless you download DWC and make the modifications yourself and make your own build of DWC. It's something I can look at but it won't be today.
Just checking to see if the change made it into the new DWC release.
@ccs86 I have not had time to make any changes to the heightmap at this point.
Just checking in.
@Sindarius said in Height Map Padding:
Do you think you might have time for this soon?
@CCS86 I made some changes to the control that will likely be in 3.5
Thank you!
Did this change make it into 3.5 beta 1?
