Connecting servo motors to duet board without ena pins
Hi, I’m considering buying 2 integrated servo motors for my scara 3d printer prototype, I have read that the pins to connect the motors are of 3 type step dir and enable. In my case the servo would have step dir and alarm pins and it would be enabled on power on.
The servo is this: https://www.omc-stepperonline.com/it/nema-23-servomotore-easy-integrato-90w-3000rpm-0-3nm-42-49oz-in-20-50vdc-servomotore-cc-senza-spazzole-isv57t-090
Do you think that it could be compatible?
What other cheap servos could I use?Thanks in advance,
gnmrc_
@gnmrc_ That servo unit looks like it will work with a Duet.
Depending on which Duet you choose, you will hook up the step and direction signals a little bit differently since they need +5 Volts DC.
But it can be used no problems.
@alankilian Thanks for the help
