Failed to enable endstops new build
Hey finished mod an old Tronxy core XY with a new Z build plate mounted 3 t8 skews true bed level is working, and calibration seems ok?
However every time I start a print I get the following error "Failed to enable endstops"
I've been pulling my hair out now for a week"
Config.g below
; Configuration file for Duet 3 MB 6HC (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.13 on Sat Oct 01 2022 13:40:55 GMT+1000 (Australian Eastern Standard Time); General preferences
M550 P"Duet 3" ; set printer name
M669 K1 ; select CoreXY mode; Drives
M569 P0.1 S0 ; physical drive 0.1 goes forwards
M569 P0.2 S0 ; physical drive 0.2 goes forwards
M569 P0.4 S1 ; physical drive 0.4 goes forwards
M569 P0.5 S0 ; physical drive 0.4 goes forwards
M569 P121.0 S1 ; physical drive 121.0 goes forwards
M584 X0.1 Y0.2 Z0.3:0.4:0.5 E121.0 ; set drive mapping
M92 X80.00 Y80.00 Z400.00 E400.00 ; set steps per mm
M566 X1800.00 Y1800.00 Z120.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z320.00 E1200.00 ; set maximum speeds (mm/min)
M84 S30 ; Set idle timeout
M671 X120:0:320 Y0:320:320 S5; Axis Limits
M208 X330 Y330 Z350 S0 ; set axis maxima; Endstops
M574 X1 S1 P"121.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 121.io1.in
M574 Y1 S1 P"io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin io1.in; Z-Probe
M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
M558 P9 C"121.io0.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y0 Z1.05 ; set Z probe trigger value, offset and trigger height
M557 X15:320 Y15:320 S24 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin temp0
M950 H0 C"out1" T0 ; create bed heater output on out0 and map it to sensor 0
M307 H0 R0.868 K0.492:0.000 D1.32 E1.35 S1.00 B0 ; disable bang-bang mode for the bed heater and set PWM limit
M308 S1 P"121.temp0" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin 121.temp0
M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
M950 F0 C"121.out2" Q500 ; create fan 0 on pin 121.out2 and set its frequency
M106 P0 S1.0 H-1 ; set fan 0 value. Thermostatic control is turned off; Tools
G10 P0 X0 Y0 Z1.945 ; set tool 0 axis offsets
@chriswhiting
post the contents of your homing filesActually, add a
G4 S3
to your config just after the M669 to allow the CAN-FD connections to come online -
@jay_s_uk [download (1).zip](Invalid file type. Allowed types are: .png, .jpg, .gif, .bmb, .pdf, .svg, .dxf, .cad, .txt, .doc, .xls, .docx, .xlsx, .stl, .csv, .g, .gcode, .stp, .step, .cps, .cbpp, .odt, .ods, .json, .scad, homex.g homeall.g homez.g homey.g .heic, .cpp, .c, .h, .py, .fcstd, .elf, .bin, .mp4, .jpeg, .hpp, .webp, .heic, .js, .qoi, .gc)
@chriswhiting trying the G4 S3 now
@chriswhiting
homex.g; homex.g ; called to home the X axis ; ; generated by RepRapFirmware Configuration Tool v3.3.13 on Sat Oct 01 2022 13:40:55 GMT+1000 (Australian Eastern Standard Time) G91 ; relative positioning ;G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-335 F1800 ; move quickly to X axis endstop and stop there (first pass) G1 X5 F6000 ; go back a few mm G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass) ;G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
homey
; homey.g ; called to home the Y axis ; ; generated by RepRapFirmware Configuration Tool v3.3.13 on Sat Oct 01 2022 13:40:55 GMT+1000 (Australian Eastern Standard Time) G91 ; relative positioning ;G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 Y-335 F1800 ; move quickly to Y axis endstop and stop there (first pass) G1 Y5 F6000 ; go back a few mm G1 H1 Y-335 F360 ; move slowly to Y axis endstop once more (second pass) ;G1 H2 Z-5 F6000 ; lower Z again G90 ; absolute positioning
homez
; homez.g ; called to home the Z axis ; ; generated by RepRapFirmware Configuration Tool v3.3.13 on Sat Oct 01 2022 13:40:55 GMT+1000 (Australian Eastern Standard Time) ;G91 ; relative positioning ;G1 H2 Z5 F6000 ; lift Z relative to current position ;G1 H1 Z-355 F1800 ; move Z down until the endstop is triggered ;G92 Z0 ; set Z position to axis minimum (you may want to adjust this) ; Uncomment the following lines to lift Z after probing ;G91 ; relative positioning ;G1 Z5 F100 ; lift Z relative to current position ;G90 ; absolute positionin ------------------------------------------------------------------------------ G91 ; relative mode ;G1 H2 Z2 F200 ; raise head 4mm to ensure it is above the Z probe trigger height G1 X0 Y0 F2000 ; put head over the centre of the bed, or wherever you want to probe G30 ; lower head, stop when probe triggered and set Z to trigger height G90 ; back to absolute mode
homeall
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.3.12 on Tue Sep 06 2022 18:33:17 GMT+1000 (Australian Eastern Standard Time) G91 ; relative positioning ;G1 H2 Z5 F6000 ; lift Z relative to current position G1 H1 X-335 Y-335 F1800 ; move quickly to X or Y endstop and stop there (first pass) G1 H1 X-335 ; home X axis G1 H1 Y-335 ; home Y axis G1 X5 Y5 F6000 ; go back a few mm G1 H1 X-335 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y-335 ; then move slowly to Y axis endstop G1 H1 Z-355 F360 ; move Z down stopping at the endstop G90 ; absolute positioning G92 Z0 ; set Z position to axis minimum (you may want to adjust this)
@chriswhiting the error is homeall tried to home with an endstop and homez homes with a probe
@chriswhiting Nup same outcome "Failed to enable endstops" just after extruder start heating
@chriswhiting add
T0
to the end of your config -
@jay_s_uk did you mean config.g ?
@chriswhiting yes
@chriswhiting I think I might have fixed the home all issue
@chriswhiting thats better.
It's also suggested to probe in the centre of the bed for homing. -
@jay_s_uk Understood that's me being inpatient
@chriswhiting Grrr calibrated my Z probe offset height to 1.28 and it's printing the first layer about 4mm above the bed?
@chriswhiting you have no X and Y offsets for your probe
G31 P500 X0 Y0 Z1.2 ; set Z probe trigger value, offset and trigger height
what type of probe is it and how did you calibrate it?
@jay_s_uk its a bltouch and I used this
@chriswhiting Tried again and changed
M558 P9 C"121.io0.in" H1.945 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
Same problem?
@chriswhiting thats not where you set the probe offset. its set using G31, the next line down from M558
