During PID tuning is it supposed to turn on part fan (fan 0)?
Scenario: NTC 100k 3950 thermistor; mosquito hotend; 50w 24v heater
M308 S1 P"e0temp" Y"thermistor" T100 B4766 C1.183652e-7 ; configure sensor 1 as thermistor on pin e0temp
I used the calculator on the configurator to come up with those numbers based on the temp table I found for the thermistor:
25c: 100k
210c 456.6
250c 223.6When running
M303 T0 S240It goes through its motions, then at the end it says "measuring with fan on"
"Which fan"? is it talking about? I'm guessing this is the part fan because tool fan comes on at 45c automatically of course.
But the part fan does not turn on during PID. They do in fact work, as M106 S255 turns them on.
@thetazzbot yes, the part cooling fan should come on.
post your config.g so we can take a look. its more than likely mapped incorrectly in M563 -
@jay_s_uk ; Heaters
; bed
M308 S0 P"bedtemp" Y"thermistor" T100000 B4085 ; configure sensor 0 as thermistor on pin bedtemp
; PID settings saved in config-override.g
M140 H0 ; assign heaer 0 to bed heater
M143 H0 S120 ; set temperature limit for heater 0 to 120C; hotend, mosquito, 50w 24v heater, ntc 3950 100K thermistor
;https://m.media-amazon.com/images/I/81UssMSx6wL.SL1500.jpg
M308 S1 P"e0temp" Y"thermistor" T100000 B4766 C1.183652e-7 ; configure sensor 1 as thermistor on pin e0temp
M563 P0 D0 H1 F1 ; define tool 0
G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0CI am having a heck of a time getting it to print. It always has huge temp fluctuations at 240c. The temp table for the thermistor is here
@thetazzbot said in During PID tuning is it supposed to turn on part fan (fan 0)?:
you've mapped the wrong fan. you map the part cooling fan here not the hotend fan. change this to F0
likely should be F0 i guess, but I think I tried that as well.
@jay_s_uk ok i'll try that. but im also suffering from massive temp variations at 240c that prevent me from printing... any tips there?
i think this is wrong unless you have a better source for that.
Using the config tool and a trying to keep it simple by using a pair of temps (25 and 240) I getT100000 B4219
I think adding 3 readings can confuse things somewhat.
