Suddenly extrusion buttons Extrude/Retract are grey!
Old habit, all my printers have T1
@tecno can't remember if there were any bugs back with 3.3.0. Best update to 3.4.1
NOT
SOLVEDError in writing config.g so I took an older one and edited necessary lines.
Got M302 P1 working and then lost connection and now I can not reach the printer. -
I have now updated DCW to 3.4.1 = still no M302 P1
Only TOOLS section was edited before all this with no filament feed occured.
https://forum.duet3d.com/topic/29618/superslicer-question/5; Configuration file for Fly-E3 (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.1-LPC-STM32+7 on Mon Mar 14 2022 20:23:48 GMT+0100 (centraleuropeisk normaltid) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"VORON" ; set printer name M669 K1 ; select CoreXY mode M564 H0 ; Network M551 P" " ; set password M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards using default driver timings M569 P1 S1 ; physical drive 1 goes forwards using default driver timings M569 P2 S1 ; physical drive 2 goes forwards using default driver timings M569 P3 S1 ; physical drive 3 goes forwards using default driver timings M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z400.00 E690.00 ; set steps per mm z400 M572 D0 S0.10 ; PA M566 X100.00 Y100.00 Z100.00 E600.00 ; set maximum instantaneous speed changes (mm/min) M203 X5000.00 Y5000.00 Z2600.00 E7200.00 ; set maximum speeds (mm/min) M201 X1500.00 Y1500.00 Z1500.00 E800.00 ; set accelerations (mm/s^2) M906 X1250 Y1250 Z400 E800 I25 ; set motor currents (mA) and motor idle factor in per cent M207 S1.5 F7200 Z0.2 ;firmware retraction M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z-3 S1 ; set axis minima M208 X120 Y100 Z110 S0 ; set axis maxima ; Endstops M574 X2 S1 P"xstop" ; configure active-high endstop for low end on X via pin xstop M574 Y2 S1 P"ystop" ; configure active-high endstop for low end on Y via pin ystop M574 Z2 S1 P"zstop" ; configure active-high endstop for low end on Z via pin zstop Z-Probe M558 P0 H5 T6000 F1500:250 ;A5 ;S.25 ; ;G31 P1000 X0 Y20 Z1.7 M557 X20:120 Y20:110 S30 ; define mesh grid ; Heaters M308 S0 A"Bed" P"bedtemp" Y"thermistor" T100000 B4092 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bed" T0 ; create bed heater output on bed and map it to sensor 0 M307 H0 B0 R1.109 C133.4 D4.22 S1.00 V0.0 ; disable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 A"Nozzle" P"e0temp" Y"thermistor" T100000 B4092 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 R2.424 C165.6 D6.10 S1.00 V0.0 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" ; // PART FAN M106 P0 S0 H-1 ; P0 = fan0 S0 = Speed 0 H-1 = Disable Termostatic mode M950 F1 C"fan1" ; // TOOL FAN M106 P1 S1 ; P1 = fan1 S1 = Speed 100% ; Tools M563 P1 H1 F0 ; P1 = tool1 H1 = heater1 F1 = fan1 G10 P1 X0 Y0 Z0 ; set tool 0 axis offsets G10 P1 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous T1 ; select first tool
@tecno have you updated the firmware too?
try switching to tool 0 -
@jay_s_uk
No, will do
What lines in config needs to be changed for T0 -
@tecno said in Suddenly extrusion buttons Extrude/Retract are grey!:
G10 P1 R0 S0 ; set initial tool 0 active and standby temperatures to 0C; Custom settings are not defined
T1 ; select first toolchange those to these
; Tools M563 P0 H1 F0 ; P1 = tool1 H1 = heater1 F1 = fan1 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous T0
OK, done that. But still no M302 P1 = all gray buttons
Updated FW = still same error
If you've changed the tool from T1 to T0, then you need to use M302 P0 not M302 P1.Edit. Ignore that crap. Next time I'll try and engage my brain before typing.....
@deckingman i thought M302 was system wide? https://docs.duet3d.com/en/User_manual/Reference/Gcodes#m302-allow-cold-extrudes
P1 = allow, P0 = not allow? -
@deckingman said in Suddenly extrusion buttons Extrude/Retract are grey!:
2022-08-18 12:57:49 M302 Cold extrusion is forbidden (use M302 P1 to allow it), min. extrusion temperature 160.0C, min. retraction temperature 90.0C 2022-08-18 12:57:39 M302 P0
@jay_s_uk said in Suddenly extrusion buttons Extrude/Retract are grey!:
P1 = allow, P0 = not allow?Oh crap - you are right of course - more caffeine needed
I hope I have finally found the error, did run RRF Config Tool and copied the config.g and now it looks lite it is working. Do have to finetune motorparameters. I can not see any differences other than speeds.
Will report my findings.
So it looks like writing data on µSD card is somehow corrupted. Is it possible the write process is too fast and no CRC or whatever to verify is done?
................ Is it possible the write process is too fast and no CRC or whatever to verify is done?
In DWC - Settings - Machine Specific, there is a toggle entitled "Use CRC32 checksums for uploads" or some such. Make sure it's "On".
Has always been ON
What makes you think there is an SD card corruption? Do you have an example of a corrupt file?
What make and size of SD card are you using? Try inserting it in a Windows PC and checking it for errors.
Hi Andy,
Config.g was damaged obviously as it did work with a new copy written on card.32G from Sandisk, no errors in Win.
@tecno So do you have the damaged version of the file? If so please post it....
