Fans on Duet2 wifi
Hi ...I'm back !
I've got things sorted and had some prints at last . Now i need to put everything back in it's box and am having a problem with the fan that will cool the motherboard. this is my Config.g but fan 2 does not show up in the console/dashboard ?
; original version generated by RepRapFirmware Configuration Tool v2.1.8 on Fri Apr 10 2020 21:58:05 GMT-0600 (Mountain Daylight Time); General preferences
M550 P"Nick's Ender +5+ " ; set printer name
M552 S1
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes forewards
M569 P1 S0 ; physical drive 1 goes forewards
M569 P2 S1 ; physical drive 2 goes forewards
M569 P3 S1
M569 P4 S1 ; physical drive 3 goes forwards
M584 X0 Y1 Z2:4 E3 ; set drive mapping
; Settings w/o interpolation - commented out
;M350 X32 Y32 Z32 E128 I1 ; configure microstepping with interpolation
;M92 X160.00 Y160.00 Z1600.00 E3533 ; set steps per mm
;M566 X600.00 Y600.00 Z60.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)120
;M203 X9000.00 Y9000.00 Z1200.00 E6000.00 ; set maximum speeds (mm/min)
;M201 X3000.00 Y3000.00 Z60.00 E2500.00 ; set accelerations (mm/s^2)250
; Settings w/ interpolation @ 16
M92 X80.00 Y80.00 Z800.00 E130.15 ; set steps per mm130.15
M566 X600.00 Y600.00 Z30.00 E300.00 ; set maximum instantaneous speed changes (mm/min)300
M203 X9000.00 Y9000.00 Z500.00 E5000.00 ; set maximum speeds (mm/min)
M201 X800.00 Y800.00 Z250.00 E1000.00 ; set accelerations (mm/s^2)1500
M906 X400 Y300 Z350 E900 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 X0 Y6 Z0 S1 ; set axis minima
M208 X350 Y350 Z400 S0 ; set axis maxima; Endstops
M574 Z0 ; disabled end stop for z c
M574 X1 S1 P"xstop" ; active low endstop for x-axis
M574 Y1 S1 P"ystop" ; active low endstop for y-axis; Filament Sensor
M591 D0 P1 S1 C"e0stop"; Z-Probe
; Based on https://duet3d.dozuki.com/Wiki/Connecting_a_Z_probe#Section_Duet_2_WiFi_Ethernet_without_expansion_board
M307 H3 A-1 C-1 D-1
M280 P5 S10 I1 :c
M950 S0 C"exp.heater3" ; Set exp.heater3 (pin8 on expansion socket) as servo pin 0 for BLTouch c
M558 P9 C"^zprobe.in" H5 F120 T6000 A5 R0.1 X0 Y) Z1 ; set Z probe type to bltouch and the dive height + speeds c
G31 P500 X-28 Y-13 Z3.54 ; set Z probe trigger value, offset and trigger height c pla3.65
M557 X0:300 Y0:300 S20 ; define mesh grid
M574 Z1 S2;c
M280 P5 S90 I1
; Sensors
; See https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
; for pin names
M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; Bed Thermistor
; I replaced my original e0temp thermistor, so if you have stock, use the same values as bed
M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; Extruder Thermistor; Heaters
M950 H0 C"bedheat" T0 ; Create a heater using the bedheat output and the S0 temp sensor (bed heater)
M143 H0 S120 ; set temperature limit for heater 0 to 120CC0.0000000706
M140 H0 ; Set heater H0 as the bed heater
M950 H1 C"e0heat" T1 ; Create a heater using the e0heat output and the S1 temp sensor (extruder 0)
M143 H1 S290 ; set temperature limit for heater 1 to 290C; Bed adjustment screw locations
M671 X15:300:300:15 Y35:40:320:320 P0.7 ; mark leveling screws at (316,295) (316,35) (46,295) (46,35); Fans
M950 F0 C"fan0" Q500 ; Set fan 0 to pin "fan0" with PWM freq 500 Hz
M106 P0 C"part-cooling" S0.10 H-1 ; set fan 0 name and fan speed to 65%. Thermostatic control is turned oncp0 h0
M950 F1 C"Fan1" Q500 ; Set fan 1 to pin "fan1" with PWM freq 500 Hz
M106 P1 C"hotend" S0.50 H1 T100 ; set fan 1 name and fan speed. Thermostatic control is turned off
M950 F2 C"fan2" Q500 ; Set fan 2 to pin "fan2" with PWM freq 500 Hz
M106 P2 C"fan2" S0.50 H1 T100 ; set fan 2 speed. Thermostatic control is turned off; Tools
M911 S12 R20 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
Thanks in anticipation of your help -
@nicaris you've set it to thermostatic against heater 1 so it won't be displayed in DWC
@nicaris Thanks for the swift response -do I just remove the H1 from that line ?
@nicaris remove the T100 and set H-1
