Solved Revo 5V fan on Duet3 mini
As per title can a Revo 5V fan be connected to a 5V pin on one of the IO Ports (I know you can on a 6HC but not to sure about the 3 Mini).
Probably a Question for DC42
TIA Doug
@dougal1957 you can take the 5v power from an IO port and then use the negative on the fan output to allow control.
