Solved Two print cooling fans with separate connection headers
Some printers run two fans as print cooling fans. One from the left side and another from the right side.
Let's say I would like to connect each fan to a separate header, but control them together at the same time (always). I know I can just group them into a single header, but for this experiment - that's not what I want.
I've been digging around, but can't find an answer.
Is it at all possible to configure two separate fans to work as a single P0 one? Let's assume my slicer sends only a simple M106 command, so we can't rely on multiple M106 P# commands. Has to be M106 S255 for example.
@pkos Yes. The way to do it is to map both fans to the tool using M563 https://duet3d.dozuki.com/Wiki/M563. So if your two fans were defined as fans 1 and 2, and you had a single tool using a single extruder, and a single heater, then your M563 would look like this M563 P0 D0 H1 F1:2. Where P is the tool number (usually 0 if you only have one tool ), D is the extruder drive to use, H is the heater, and F is/are the fans.
@deckingman Oh wow. I missed that bit. Thank you!
