PanelDue Firmware 3.4.0 released
Hallo,
here a new official version of PanelDue.
Special thanks goes out to @Fred-Y, @cosmowave, @Aitor, @RomanVin who helped me to review and fix most translations.
Release Notes 3.4.0
This release requires RepRapFirmware 3.3 or later.
Version 2 (after August 2016) and Version 3 PanelDue are supported.
- add cross-platform headless builds based on cmake
- cleaned up dim/screensaver handling
- removed compiler warnings
- enabled Russian localization by default
- enabled Ukrainian localization by default
- improved list-locales tool for translation debugging
- fixed displaying of M291 S2 and S3 if followed by M292
- fixed displaying macro buttons in control tab
- fixed setting of serial baud rate after reboot
- cleaned up English
- cleaned up Czech translation
- cleaned up French translation
- cleaned up German translation
- fixed access to second sd card
- cleaned up Russian translation
- fixed persistent pressed button handling in some dialogs
- fixed updates via RRF
- fixed displaying of multiple heaters per tool
- improved readme
- fix brightness handling during pop-ups
- disabled spammy debug information
- show babystep button if printer is idle
- cleaned up Spanish translation
- change default feedrates
- extend m291 popup to allow movement of other axis, up to 10
- updated RRFLibraries
- fixed babystep button alignment in setup tab
- moved popup code into separate module
- show connection loss in status
- show warning when more than 2 malformed successive request responses are received
- log status changes console
- add support for ccache to speed up compilation
Downloads and flashing instructions:
Binaries can be found at https://github.com/Duet3D/PanelDueFirmware/releases/tag/3.4.0
Flashing instructions can be found at https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
undefined mfs12 referenced this topic
undefined mfs12 pinned this topic
undefined mfs12 unpinned this topic
