panel due 5i not connecting
@adhanabal said in panel due 5i not connecting:
duet2 wifi board with firmware version 1.23
You said same paneldue is working with your duet2 wifi board with firmware version 1.23? Are you sure that paneldue is having the running version 3.3? I don't think RRF-1.23 and PanelDue-3.3 are compatible.
@mfs12 I reflashed the fimware to 1.23 for checking with duet wifi 2
@adhanabal, and what happened?
@mfs12 the panel due worked with duet2wifi board
so you tested:
- connected firmware paneldue-5.0i with firmware 3.3
- with Duet2 Wifi with 1.23 firmware
- and this was successful.
If not, please provide a detailed step-by-step procedure.
your paneldue has probably old version. Check the top in the setup tab.
@mfs12 I will post photos tmw,
And I said I use panel due version 3.0
I will provide complete details tmw with photos -
then please upgrade to paneldue's to firmware version 3.3.
I think paneldue-3.0 is incompatible with newer RRF versions. Sorry, for the inconvenience.
@mfs12 hi i have attached images for your reference, pls check , and also let me know i have wired it correctly.
@mfs12 hello all
it was my mistake my wiring was wrong i did not properly look at instructions page, thank you for helping me out,
please close this issue. -
@adhanabal thanks for feedback. Enjoy printing...
