sensor ir
@sgk
; ===================== Drive Settings ===================== M350 X16 Y16 Z16 E16 I1 ; Configure microstepping with interpolation M92 X200,120 Y200,541 Z800 E714.36 ; Set steps per mm for orbiter
Replace the comas with a dot after that go to the console and enter g98 P"config.g" and post the result.
When you now enter M119 in the console look if the Z probe is triggered if it so change the following lineM558 P1 C"^zprobe.in" H5 F200 T9000 I0 R0.5 ; Set Z probe type mini ir sensor
to
M558 P1 C"!^zprobe.in" H5 F200 T9000 I0 R0.5 ; Set Z probe type mini ir sensor
an retest with M119
@siam i have M119
Endstops - X: not stopped, Y: not stopped, Z: at min stop, Z probe: at min stop -
@sgk have you made the changes which I have provided in my last post? And can you post the result of M98 P"config.g"
when I do Calibrate the Z probe trigger height the bed crashed into the nozzle when I hit g30 s-1
@sgk trigger height needs to be a positive value for the IR probe in RepRapFirmware.
thank you for answering me.
when i type g30 s-1 the bed doesn't stop -
is normal -
@sgk if you have the gantry high enough do that you can trigger the probe by putting your finger under it, can you see that the z probe value on DWC goes up?
Also, what kind of bed material do you use?
@sgk this bed
@sgk pei sheet is semi transparent and I've had mixed success with the IR board on it. I take it you also tested it with the paper underneath?
@oliof yes yes but the bed does not stop
@sgk @oliof, I maybe off base but would it be worth trying the probe in mode 8? this is the way my IR sensor is configured, then use the paper with the bed well out of the way to trigger a response?
I will try
