connecting x endstop switch on toolboard ?
Just checked mine. I use 3.3v and io.in
HTH
nothing, like dead.
i changed the the pin to +5v and io2.in on 121.io2.in and also on io1.
nothing
M119 is Endstops - X: at min stop
always with or without connected endstop also pressing the endstop or not doesnt make an differentfirmware on duet 6 and toolboard is 3.3
@joeko Care to share your config.g, just incase...
; Configuration file for Duet 3 (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.4 on Sat Oct 23 2021 07:25:18 GMT+0200 (Mitteleuropäische Sommerzeit); General preferences
M80
M550 P"Vcore" ; set printer name
M669 K1 ; select CoreXY mode; Wait a moment for the CAN expansion boards to start
G4 S2; Network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0.0 S0 D3 H5 v5 ; physical drive 0.0 goes backwards
M915 P0.0 T5
M569 P0.1 S0 D3 H5 v5 ; physical drive 0.1 goes forwards
M915 P0.1 T5
M569 P0.2 S0 D3 H5 v5 ; physical drive 0.2 goes backwards
M915 P0.2 T5
M569 P0.3 S0 D3 H5 v5 ; physical drive 0.3 goes backwards
M915 P0.3 T5
M569 P0.4 S0 D3 H5 v5 ; physical drive 0.4 goes forwards
M915 P0.4 T5
M569 P121.0 S0 ; physical drive 121.0 goes backwards
M584 X0.4 Y0.1 Z0.0:0.3:0.2 E121.0 ; set drive mapping
M92 X80.00 Y80.00 Z800.00 E854.29 ; set steps per mm
M566 X900.00 Y900.00 Z30.00 E1500.00 ; set maximum instantaneous speed changes (mm/min)
M203 X12000.00 Y12000.00 Z200.00 E3600.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z30.00 E1500.00 ; set accelerations (mm/s^2)
M906 X1900 Y1900 Z1900 E870 I50 ; set motor currents (mA) and motor idle factor in per cent
M208 X290 Y280 Z270 S0 ; set axis maxima; Endstops
M574 X1 S1 P"121.io1.in" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin 121.io2.in
M574 Y2 S1 P"io6.in" ; configure switch-type (e.g. microswitch) endstop for high end on Y via pin io6.in
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z leadscrew positions
M671 X-60:358:126 Y-25:-25:358 S4; Z-Probe
M950 S0 C"121.io0.out" ; create servo pin 0 for BLTouch
M558 P9 C"^121.io0.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-30 Y-17 Z2.5 ; set Z probe trigger value, offset and trigger height
M557 X20:280 Y20:270 S75 ; define mesh grid; Heaters
M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
M950 H0 C"out0" T0 Q10 ; create bed heater output on out0 and map it to sensor 0
M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin 121.temp0
M950 H1 C"121.out0" T1 ; create nozzle heater output on 121.out0 and map it to sensor 1
M143 H1 S285 ; set temperature limit for heater 1 to 280C; Fans
M950 F0 C"121.out2" Q500 ; create fan 0 on pin 121.out1 and set its frequency
M106 P0 S0 H1 T45 ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"121.out1" Q500 ; create fan 1 on pin 121.out2 and set its frequency
M106 P1 S0 H-1 ; set fan 1 value. Thermostatic control is turned on; Tools
M563 P0 S"E3D" D0 H1 F1 ; define tool 0
T0; Custom settings are not defined
M501 ; load saved parameters from non-volatile memory -
i suppose i got it.
it is an makerbot switch and it has to be connected as an makerbot switch with all 3 wires
