Help request testing and calibrating BLTouch
Hi, I didn't see any questions that answered my question but I would love to be wrong and pointed to the right page. Thanks for reading.
Here's the steps I followed, per
https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe
and
https://betrue3d.dk/bltouch-on-duet-wifi-configuratio-and-usage/Ender 3 (no Pro, no V2)
Duet 2 WiFi/Ethernet v1.04, firmware updated to 3.3
BLTouch V2.0
All wires are correct and seated
I edited the X and Y offset of the BLTouch to correspond to my mounting location.(0) deployed sensor is about 2.5mm below nozzle
(1) deploy and retract work as normal
(2) dynamic test works
(3) I jog the nozzle down until it is just gripping a feeler gauge (0.10mm). During this step the BLTouch is triggered with Z-Probe value of 1000.
(4) G92 Z0
(5) Jog the head up 10mm. At this point I am unable to retract/deploy the probe.
(6) G30 S-1
Error: Probe already triggered at start of probing move
Also, I am unable to deploy the sensor unless I power cycle.===========================================================
M98 P"config.g"
HTTP is enabled on port 80
FTP is disabled
TELNET is disabledConfig per https://configtool.reprapfirmware.org
config.g
; Configuration file for Duet WiFi (firmware version 3.3)
; generated by RepRapFirmware Configuration Tool v3.3.2 on Sat Sep 25 2021; General preferences
M550 P"Waterfall" ; set printer name; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P0 S0 ; physical drive 0 goes backwards
M92 X80.00 Y80.00 Z400.00 E103.00 ; set steps per mm
M566 X900.00 Y900.00 Z24.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
M203 X9000.00 Y9000.00 Z180.00 E1200.00 ; set maximum speeds (mm/min)
M201 X300.00 Y300.00 Z100.00 E250.00 ; set accelerations (mm/s^2)
M84 S300 ; Set idle timeout; Axis Limits
M208 X220 Y220 Z250 S0 ; set axis maxima; Endstops
M574 Z1 S2 ; configure Z-probe endstop for low end on Z; Z-Probe
M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
G31 P500 X-50 Y-15 Z0 ; set Z probe trigger value, offset and trigger height
M557 X15:215 Y15:215 S20 ; define mesh grid; Heaters
M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off; Tools
M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power lossdeployprobe.g
; deployprobe.g
; called to deploy a physical Z probe
; generated by RepRapFirmware Configuration Tool v3.3.2 on Sat Sep 25 2021 05:31:30 GMT-0400 (Eastern Daylight Time)
M280 P0 S10 ; deploy BLTouch -
Okay, I think I figured it out. In https://configtool.reprapfirmware.org/Endstops it doesn't automatically select Z-probe in the endstop type for the Z axis when you select BLTouch. When I did so, it seems to have solved my issue.
