Contradicting M122 and M584; "Driver not found"
I've been using the same config for about a month, and recently moved. During my first startup after 2 weeks of no printing, my printer said 1 of the drivers was not found. This was very strange because zero changes were made to the wiring or the firmware. I checked to see if my 3HC expansion board (address 2) was being found, and it was; the driver appeared to be showing up properly.
So I tried to send the M584 command in the console, to see if it would still return the error. Of note, all axis are linear, including "A" which is on 2.2Running 3.4B3
@kevinmar
For some bizarre reason, "Emergency Stop"-ing the machine works, and all the sudden the driver seems to be found by the machine when trying to move that axis. Why would this be? -
@kevinmar do you have a G4 S2 in your config before any reference to a CAN board is made?
@jay_s_uk Yes
Why would an Emergency Stop yield different results than a config save or a power on startup?
