Solved Duet 2 wifi - driver 10 and 11 on CONN_LCD
Hello, i have 2 driver HBS57 wiring
https://i0.wp.com/s1.uphinh.org/2021/09/14/image110877081bb6fcce.png
I connect:
PUL+ of driver 1 with 9)Stp 10 (LCD_DB5)
DIR+ of driver 1 with 7)Dir 10 (LCD_DB6)
ENA+ of driver 1 (no connect)
PUL+ of driver 2 with 10)Stp 11 (LCD_DB4)
DIR+ of driver 2 with 8)Dir 11 (LCD_E)
ENA+ of driver 2 (no nonnect)
PUL- and DIR- of driver 1,2 with 2) GND
Only driver 1 work, i swap driver 1 to driver 2 but only driver connect with Stp 10 and Dir 10 work, Stp 11 and Dir 11 not work.
My firmware:
; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Feb 24 2021 21:49:41 GMT+0700 (Indochina Time)
;PanelDue
M575 P1 B57600 S1; General preferences
M550 P"HMQ Printer" ; set printer name
M669 K1 ; select CoreXY mode; Network
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M569 P4 S0 ; physical drive 4 goes forwards
;M569 P5 S0 ; physical drive 3 goes forwards
M569 P10 S0 ; physical drive 3 goes forwards
;M569 P11 S1 ; physical drive 3 goes forwards
M569 P5 S1 T5:2.5:5:7.5 ; physical drive 3 goes forwards
M569 P7 S1 T5:2.5:5:7.5 ; physical drive 3 goes forwards
M584 X10 Y11 Z0:1:3 E4 ; set drive mappingM671 X24:292:155 Y35:35:300 S10 ;Toa do can ban ma tran
M92 X250 Y250 Z800 E394 ; set steps per mm
M201 X500.00 Y500.00 Z10.00 E250.00 ; set accelerations (mm/s^2)
;M201 X10000 Y10000 Z10 E250 ; test gia toc cao
M208 X288 Y285 Z300 S0 ; set axis maxima; Endstops
M574 X1 S1 P"xstop" ; configure sensorless endstop for high end on X
M574 Y1 S1 P"ystop" ; configure sensorless endstop for high end on Y
M574 Z1 S2 ; Define Z to use Probe. Home to Min; Z-Probe
;M950 S0 C"duex.pwm5" ; create servo pin 0 for BLTouch
M558 P5 C"!^zprobe.in" I1 ; set chan cam bien Z
;M558 P9 C"^zprobe.in" H5 F120 T6000 ; set Z probe type to bltouch and the dive height + speeds
;M280 P0 S90 ;send control signal to BLTouch through servo/gpio 0
G31 P500 X4 Y35 Z1.85 ; set Z probe trigger value, offset and trigger height
M557 X4:292 Y35:320 S19.1:18.9 ; define mesh grid; Heaters
M307 H0 B1 R0.896 C85.5 D1.72 S1.00 V24
;M307 H0 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
;M307 H1 R2.573 C78.2 D5.54 S1.00 V24
;G29 S1 ; Load height map from file; Miscellaneous
T0 ; select first tool
Pls help me -
Driver 11 didn't work, there's a bug fix note in the RRF 3.3 release notes:
[Duet WiFi/Ethernet] Driver 11 connected to CONN_LCD did not work. It should now work provided that you have not configured a 12864 LCD.
https://github.com/Duet3D/RepRapFirmware/wiki/Changelog-RRF-3.x#reprapfirmware-33
Make sure that you are runing RRF 3.3 (and update DWC to the same version as well), and try again.
@oliof tks very much, i will try up to FW 3.3, i have use fw 3.2
@oliof now, i can use driver 11 after update fw 3.3
tks u very much
