Piezo Orion stopped working after update to RRF v3.3
Hi folks,
I updated my delta printer with a Duet WiFi to RRF v3.3 from v2.05, I know a few things changed in the config one of those M558.
I had the piezo working correctly before with M558 P5 I1 R0.4 F300 X0 Y0 Z0.
I changed it to M558 P1 C"zprobe.in" I1 R0.4 H5 F300 X0 Y0 Z0 it does try to probe but I get an "Error: Probe already triggered at start of probing move" I can see under "Z probe" in the dashboard it shows highlighted in red 456 and when I tap the piezo goes down to zero and back up again it does detect the taps.
I have tried changing I1 to I0 in different combinations with P1, 2, 5, and 8 but I can get it to work I still get the same error.
Could you folks guide me on what are the correct settings that I should be using? Thank you all for your help. -
I found the solution "M558 P8 C"^!zprobe.in" R0.4 H5 F300 X0 Y0 Z0" That did it
