New core-xy moves wrong
When i jog the Y axis only the X move to the right. This is my first encounter with a corexy, im not sure whats going one with the odd movements.
https://drive.google.com/open?id=1vrgOj5paX6L6XUfIhekVto4ogg_T0IHTWg
Any help is welcome
[c]
Config.g
No recorded activity before August 27, 2017
All selections cleared All selections cleared; Configuration file for Duet WiFi (firmware version 1.17)
; generated by RepRapFirmware Configuration Tool on Sun Aug 20 2017 11:15:55 GMT-0700 (Pacific Standard Time); General preferences
M111 S0 ; Debugging off
G21 ; Work in millimetres
G90 ; Send absolute coordinates…
M555 P2 ; Set firmware compatibility to look like MarlinM667 S1 ; Select CoreXY mode
M208 X350 Y350 Z700 S0 ; Set axis maxima; Endstops
M574 X1 Y1 Z2 S1 ; Define active high microswitches
M558 P0 X0 Y0 Z0 H5 F120 T6000 ; Set Z probe type to switch, the axes for which it is used and the probe + travel speeds
G31 P600 X0 Y0 Z2.5 ; Set Z probe trigger value, offset and trigger height
M557 X15:335 Y15:335 S20 ; Define mesh grid; Drives
M569 P0 S0 ; Drive 0 goes backwards
M569 P1 S0 ; Drive 1 goes backwards
M584 X4 Y0 Z2 E3 ; Apply custom drive mapping
M350 X32 Y32 Z64 E16 I1 ; Configure microstepping with interpolation
M92 X350 Y350 Z1200 E420 ; Set steps per mm
M566 X900 Y900 Z12 E120 ; Set maximum instantaneous speed changes (mm/min)
M203 X6000 Y6000 Z180 E1200 ; Set maximum speeds (mm/min)
M201 X800 Y800 Z250 E250 ; Set accelerations (mm/s^2)
M906 X1000 Y1000 Z1800 E800 I45 ; Set motor currents (mA) and motor idle factor in per cent
M84 S10 ; Set idle timeout; Heaters
M143 S260 ; Set maximum heater temperature to 260C
M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1; Tools
M563 P0 D0 H1 ; Define tool 0
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Network
M550 PCaslte ; Set machine name
M552 S1 ; Enable network
M587 SMakerSpace MakerLAN P"aruino1" ; Configure access point. You can delete this line once connected
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Disable FTP
M586 P2 S0 ; Disable Telnet; Fans
M106 P0 S0.3 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off
M106 P1 S1 I0 F500 H1 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on
M106 P2 S1 I0 F500 H1 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on; Custom settings are not configured[/c]
I was similarily confused when setting up my CoreXY. Did you read the documentation here https://duet3d.com/wiki/Configuring_RepRapFirmware_for_a_CoreXY_printer, espacially the part after the M569 commands and the testing? That helped me getting it right in the end.
Also there was a change in 1.19 that requires to either swap the X and Y motors or change the directions parameters in the M569 commands for the motors.
I hope I could help…
