Ender 3 v2 Clone/ Aquila
Hia,
I not sure of the best place for providing my RRF firmware config, so your more than welcome to move it. Please use at your own risk.The board used is: a fly e3 rrf edition.
The bed is the classic glass, with a whamBam PEX sheet stuck to it.
Bltouch is mounted using the ender 3 standard mount, and the x carriage for the printer is a Mod back plate with wholes for MGN12 rail, standard ender 3 spaced v slot wheels, and various holes for the various hotends including stock and hemera, and direct drive.My x carriage has a cloned micro swiss hotend, with the standard fan shroud and bltouch setup.
My extruder is a bmg cloned dual drive extruder.
My Y axis other than the glass and whambam sheet is the standard setup.
My Z axis is using anti-backlash nuts with the spring, it is a dual z axis setup and the lead screws terminate in a bearing block. The leads screws are attached to the motor via springy type coupler. May upgrade to the spider coupler at a later stage.
Potential upgrades for this machine would be dual MGN12 rails for the z Axis and y axis, and the extruder/hotend assembly may be converted to the afterburner with stock probe.
Knowing that my back plate for the X axis already supports mgn12 rails, it may remain bowden.
The config files are as follows:
@npm1 feel free to send me a PR. we host user created configs here https://github.com/TeamGloomy/LPC-STM32-RRFUserConfigs for the LPC/STM port
@jay_s_uk oh great I was going to manually past all of the code
