Loss of z axis.
@craigylad86 and you want me to change the commands to controle z to go through port e0 and use that as a route.
So I have to then reconfigure a section of the program. -
https://duet3d.dozuki.com/Wiki/Duet_Wiring_Diagrams
E1 is next to the extruder heater , so you want to jump from the 2 plug Z plugs to the other side.
also you need to do a configuring ?
M569 P4 S1 to what P2 was and M584 X0 Y1 Z3 E4
So your first extruder is now the Z and E1 your first extruder.
@peter247 ok that diagram is brilliant thanks.
I have z2 available
And e1 available.
Would the z2 also be affected by my malfunctioning z chip?Should I just go straight to e1?
@craigylad86 said in Loss of z axis.:
I have z2 available
And e1 available.You mean you have only 1 plug in Z2 and the other are jumper ?
the 2 Z plugs are the same driver but the 2 plugs are wired in series.yes move z to e1
M569 P0 S1 ; physical drive 0 goes backwards
M569 P2 S? ****** remove this
M569 P3 S0 ; extruder
M569 P4 S? ****** add this extruder E1 is now Z? = what s was before , us you direction setting NOT MINE.
M584 X0 Y1 Z4 E3
@peter247
My drives
Same as your except my m584
My readsM584 x0 y1:3 z2; apply drive mapping to axis
@peter247
Good news guys..I have now altered the config.
As follows
M569 P0 S0 ; Drive goes forwards
M569 P1 S1 ; Drive goes forwards
M569 P2 S0 ; Drive goes forwards
M569 P3 S1 ; Drive goes forwards
M584 X0 Y1 Z4 E3I have now a functional z axis. 🥳
But I have a new problem.
I have 2 y axis stepper motors.
Since I have change this config I have only 1 working.Any suggestions please
Do I change the m584 part so it's y2?
Or is that something different? -
M584 X0 Y1 Z4 E3
M584 X0 Y1:3 Z4 E2 (unless you're on 3.3.0 where you can omit the E entirely)
@jay_s_uk
absolutely Bluddy brilliant..I am now up and running again..
Thank you so much both of you
@jay_s_uk
no way
Z is now running in reverse.. -
@craigylad86 add an M584 line for P4
