Wrong messurements on printed parts
Hello i`m new in duet stuff. I have a duet wifi in a custom delta. 320mm circular heated bed. i make the autolevel, then run mesh grid compensation save everyting and print. A cube whete need to me 20x20x20 is make it like the photos. what can i do? Best regards http://imgur.com/a/tawzR
I made a cube 20x20x5mm with a 2mm wall and this is the messurements http://imgur.com/a/IrI7J
So if X and Y are inconsistent, I'd check belt tension. The second set of images show a pretty good cube except for the 20.15mm side.
Also be aware that whilst a 20x20x5 cube is quick to print its quite small and errors are hard to spot.
Try a 40x40x40 cube but make it open topped 2 layers base and 2 perimeters, and hollow to save time/filament.
how can i know whats the right belt tension? regards
They all need to be the same. Fairly tight, but don't go crazy, some people use guitar tuning apps.
