Duet 2 Wifi - First Time playing with Pressure Advance
Hello together!
I am currently "playing" for the first time with Pressurce advance, and must take care that this function protects the pressure-protected "strong" rectangle!
Now I have read man should pay the jerk for the extruder, I have also heard these belong from 5mm / sec to 10mm / sec!But since I am still completely new to the subject, I wanted to ask for your help, whether you could give me tips on how best to set up or configure Pressure Advance.
I have currently determined a K-factor of 1.3 and stored this in Prusaslicer via the filament G-Code!
The corners are now a lot nicer.I'm just wondering if my value of 10mm / sec jerk at the extruder isn't too much?
And whether my other values like acceleration and so on are correct?config.g:
; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S0 ; physical drive 1 goes backwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S0 ; physical drive 3 goes backwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z1600.00 E415.00 ; set steps per mm ;M566 X720.00 Y720.00 Z120.00 E300.00 ; set maximum instantaneous speed changes (mm/min) M205 X8 Y8 Z5 E10 ; Set max instantaneous speed change in mm/sec jerk M203 X12000.00 Y12000.00 Z300.00 E6000.00 ; set maximum speeds (mm/min) M201 X2000.00 Y2000.00 Z120.00 E1500.00 ; set accelerations (mm/s^2) M906 X1250 Y1250 Z1000 E1000 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S180
Speed Settings in Prusa Slicer:
Hope everybody can understand what i mean, because my English Skills are not very good.
Kind Regards from Austria
If your Linear Advance K value is 1.3 for RRF it should look like this:
M572 D0 S1.3
Your jerk and acceleration values look fine to me.
@Argo said in Duet 2 Wifi - First Time playing with Pressure Advance:
M572 D0 S1.3
this is exact this what i have entered in my Filament Start Gcode in Prusa Slicer.
So 10mm/s Jerk is not too much? -
Got my extruder even at a higher jerk value.
If you don't hear any clicking it won't be a problem. -
If you don't hear any clicking it won't be a problem.Thank you
