printer movement on startup
How do I disable printer z+ movement when I turn on the printer?
@Orang_ Please post the config.g and config-override.g
Normally there is no movement
; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M669 K10 U170 L319 R55.94 A-45:52 B135 H439.2 X-60,Y60,Z180 M666 X0 Y0 Z0 M579 X1.0171 Y1.0309 ; Network M552 S1 ; enable network M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards using default driver timings |D3 stealthChop2 M569 P1 S1 ; physical drive 1 goes forwards using default driver timings M569 P2 S1 ; physical drive 2 goes forwards using default driver timings M569 P3 S0 ; physical drive 3 goes forwards using default driver timings M584 X0 Y1 Z2 E3 ; set drive mapping M350 X64 Y64 Z64 E64 ; configure microstepping with interpolation M92 X1761. Y1761. Z1761. E1488.59 ; set steps per mm 1761.5 1488.59 M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min) M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z500.00 E1000.00 ; set accelerations (mm/s^2) M906 X500 Y500 Z500 E600 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 Z-40:300 ; set minimum Z ; Endstops M574 X2 S1 P"!xstopmax" ; configure active-high endstop for low end on X via pin xstop M574 Y2 S1 P"!ystopmax" ; configure active-high endstop for low end on Y via pin ystop M574 Z2 S1 P"!zstopmax" ; configure active-high endstop for low end on Z via pin zstop ; Z-Probe M558 P5 C"^zstop" H10 F1200 T1000 A3 ; M557 R130 S20 ; define mesh grid G31 X0 Y0 Z3.67 P500 h10 ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4600 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bed" T0 ; create bed heater output on bed and map it to sensor 0 ; disable bang-bang mode for the bed heater and set PWM limit M307 H0 R0.826 C133.9 D1.46 S1.00 V0.0 M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4072 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 R2.707 C226.1 D3.97 S1.00 V0.0 ; disable bang-bang mode for heater and set PWM limit M143 H1 S260 ; set temperature limit for heater 1 to 280C M570 H1 P5 T15 ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P2 S"2rr" D0 H1 F0 ; define tool 2 G10 P2 X0 Y0 Z-23.3 ; set tool 2 axis offsets G10 P2 R0 S0 M563 P5 S"TEST" D0 H1 F0 ; define tool 2 G10 P2 X0 Y0 Z-29.3 ; set tool 2 axis offsets G10 P2 R0 S0 ; Custom settings are not defined ; Miscellaneous T2 M575 P1 B57600 S0
whats in your tool change files for T2?
tfree2, tpost2, tpre2 - I removed them because they were not needed
@Orang_ Change the T2 to T0 in config.g? From those differing tool Z heights, you do have a tool changer?
@Stephen6309 said in printer movement on startup:
at t0 the same thing,
@Orang_ I figured it out, it is the effect of the tool offset in Z. But how to make the printer not react when loading
good question I have the same effect and always wondered what it is
@taconite Well, apparently, after loading the initial settings, the tool is loaded with an offset
@Orang_ You have different heights above the bed for you nozzle. T0 will reach the bed, but T1 and T2, won't.
@Stephen6309 Thank you. I know. I set the correct offset value at t0. tool t1,t2 are experimental, but still if the tool offset is set, the printer raises the Z-axis when it is turned on
