New tool too close to Z axis limit. Aborting tool change
After upgrading my Duet2 Wifi firmware to 3.2, I keep getting T0
Error: New tool too close to Z axis limit. Aborting tool changeI am using a delta
@ken340 post your config please
; generated by RepRapFirmware Configuration Tool v2 on Tue Feb 26 2019 21:31:01 GMT+0000 (Greenwich Mean Time); General preferences
M83 ; ...but relative extruder moves; Delta Settings
M665 L430.000 R227.000 H421.60 B185.0 X0.0 Y0.0 Z0.0 ; Set delta radius, diagonal rod length, printable radius and homed heightM666 X0 Y0 Z0 A0.00 B0.00 ; Put your endstop adjustments here, or let auto calibration find them
M550 P"Anycubic Predator" ; Set machine name
M551 P"" ; Set password
M552 S1 ; Enable network and acquire dynamic address via DHCP
M586 P0 S1 ; Enable HTTP
M586 P1 S0 ; Enable FTP S1 = enable S0 = disable
M569 P0 S0 ; Drive 0 goes forwards
M569 P1 S0 ; Drive 1 goes forwards
M569 P2 S0 ; Drive 2 goes forwards
M569 P3 S0 ; Drive 3 goes backward
M584 X0 Y1 Z2 E3 ; set drive mapping; Stepper Configuration
;M92 X80 Y80 Z80.00 E423.5 ; Set steps per mm 1.8
M92 X160 Y160 Z160 E423.5
M906 X2400.00 Y2400.00 Z2400.00 E1000.00 I30 ; Set motor currents (mA) and motor idle factor in per cent
M84 S30 ; Set idle timeout; Normal Speed
M566 X1200 Y1200 Z1200 E3600 ; Set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E10000 ; Set maximum speeds (mm/min)
M201 X3500.00 Y3500.00 Z3500.00 E3500.00 ; Set accelerations (mm/s^2); Retraction
;M207 S2.5 F7000 R0.1 T2500 Z0.5 ; Firmware retraction; Axis Limits
M208 Z0 S1 ; Set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop; Z-Probe
M558 P8 F500 H4 R0.4 C"zprobe.in+zprobe.mod" ; Set Z probe type to switch and the dive height + speeds
G31 P100 X0 Y0 Z-0.131 ; Z16.927 Set Z probe trigger value, offset and trigger height
M557 R120 S12 ; Define mesh grid S25
G29 S1 ; Load the heightmap; Bed Heater
M308 S0 A"Ultrabase Pro" P"bedtemp" Y"thermistor" T100000 B4300 C0 R4700 ; Set thermistor + ADC parameters for heater 0
M950 H0 C"bedheat" Q100 T0 ; create bed heater output on bedheat and map it to sensor 0
M307 H0 A137.8 C533.3 D1.5 V24.3 B0 ; Disable bang-bang mode for the bed heater and set PWM limit
M143 H0 S100
M140 H0 P0 ; Create bed Heater and heater limit to 120C; Extruder Heater
;M308 S1 A"E3D V5 Clone" P"e0temp" Y"thermistor" T100000 B4300 C0 R4700 ; PT100 Temperature Sensor ;C0 B4300
M308 S1 A"E3D V6 Clone" P"spi.cs1" Y"rtd-max31865"
M950 H1 C"e0heat" T1
M307 H1 A679.6 C215.6 D4.4 S1.00 V24.2 B0 ; create nozzle heater output on e0heat and map it to sensor 1M305 P1 X200 ; Set thermistor + ADC parameters for heater 1
M143 H1 S240 ; Set temperature limit for heater 1 to 240C; Fans
M106 P0 S0 I0 F500 H-1 L0.5 ; set fan 0 value. Thermostatic control is turned off
M950 F1 C"!fan1" Q500 ; create fan 1 on pin fan1 and set its frequency
M106 P1 S0 I0 H1 T45 ; set fan 1 value. Thermostatic control is turned on;Fans
;M950 F0 C"!fan0" Q500 ;HOTEND FAN create fan 1 on pin fan1 and set its frequency
;M106 C"HotendFA" P1 I0 H1 T45 ; set fan 1 value. Thermostatic control is turned on;M950 F1 C"fan0+exp.pb6" Q500 ;CPAP create fan 0 on pin fan0 and set its frequency !fan2+exp.pb6 with RPM readout on PB6
;M106 C"CPAP" P0 S0 H-1 L0.5 ; set fan 0 value. Thermostatic control is turned off L0.3 X1;Fans
;M950 F1 C"fan0" Q500 ;HOTEND FAN create fan 0 on pin fan0 and set its frequency
;M106 C"throat" P1 I0 H1 T45 ;set fan 1 value. Thermostatic control is turned on;M950 F0 C"fan1+exp.pb6" Q500 ;CPAP create fan 1 on pin fan1 and set its frequency !fan1+exp.pb6 with RPM readout on PB6
;M106 C"Hotend Fan" P0 S0 H-1 L0.5 ;X0.5 ; set fan 0 value. Thermostatic control is turned off L0.3 X1; Tools
M563 P0 D0 H1 F0 ; tool 0 uses extruder 0, heater 1 (and fan 0)
G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C; Automatic saving after power loss is not enabled
M591 D0 P2 C"e1_stop" S1 ; activate Filament Sensor
M404 N1.75 ; Set for print monitor
M575 P1 B57600 S1 ; Paneldue baud rate; Miscellaneous
M501 ; Load saved parameters from non-volatile memory -
; config-override.g file generated in response to M500 at 2021-02-09 00:16
; Delta parameters
M665 L424.566:424.566:424.566 R219.579 H421.523 B185.0 X0.234 Y0.361 Z0.000
M666 X1.215 Y-1.023 Z-1.023 A-0.65 B0.24 ;z-1.023
; Heater model parameters
M307 H0 R0.258 C533.300:533.300 D1.50 S1.00 V24.3 B0
M307 H1 R3.152 C215.600:215.600 D4.40 S1.00 V24.2 B0
; Workplace coordinates
G10 L2 P1 X0.00 Y0.00 Z0.00
G10 L2 P2 X0.00 Y0.00 Z0.00
G10 L2 P3 X0.00 Y0.00 Z0.00
G10 L2 P4 X0.00 Y0.00 Z0.00
G10 L2 P5 X0.00 Y0.00 Z0.00
G10 L2 P6 X0.00 Y0.00 Z0.00
G10 L2 P7 X0.00 Y0.00 Z0.00
G10 L2 P8 X0.00 Y0.00 Z0.00
G10 L2 P9 X0.00 Y0.00 Z0.00
M486 S-1 -
nothing jumps out at me as being incorrect with that config to cause the error you're seeing.
I take it you have changed the stepper motors to 0.9 degree ones? I hope you have some sort of cooling on the board for the current settings you have.@ken340 said in New tool too close to Z axis limit. Aborting tool change:
F and I aren't valid here.
There no point loading the height map here as it gets unloaded when G28 is ran.
Can you check the output of M98 P"config.g" and provide the start section of a gcode file? Do you also use start.g?
Look at your homedelta.g file
There are some lines that will put the head down a bit after homing. Still using H1 there will make it fail. Use the H2 to move the motors down a bit.
@jay_s_uk I actually bought the same 0.9 stepper as in your guide.
how should I configure M106?
I somehow overcome this by manually home and set T0 temp to 50 then turn off.
@ken340
This would be typical for your fan settingsM106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on
