First trigger height way off than following
Hi there,
i upgraded my Anycubic Predator (delta printer) with the duet smart effector. I noticed when i calibrate the trigger height the first probe is often much more off than the following probes: (probing at the same XY location!)
10.2.2021, 12:51:38 M98 P"0:/macros/trigger height" Stopped at height -0.206 mm 10.2.2021, 12:51:35 M98 P"0:/macros/trigger height" Stopped at height -0.212 mm 10.2.2021, 12:51:33 M98 P"0:/macros/trigger height" Stopped at height -0.206 mm 10.2.2021, 12:51:32 M98 P"0:/macros/trigger height" Stopped at height -0.199 mm 10.2.2021, 12:51:29 M98 P"0:/macros/trigger height" Stopped at height -0.193 mm 10.2.2021, 12:51:27 M98 P"0:/macros/trigger height" Stopped at height -0.206 mm 10.2.2021, 12:51:24 M98 P"0:/macros/trigger height" Stopped at height -0.193 mm
As i am using 0.9° steppers the difference should only be 0.006 mm. Whats the problem here?
thank you
try this macro.
it does 10 checks with average. this will give a better overview.have you adjusted the sensitivity of the smart effector? maybe its note sensitive enough.
no i use the stock smart effector values. I think you forgot the macro or i am blind?
