Changing fan out from out9 to out5 has no effect
well he said his wiring is not the problem, so
@Veti Well it is spinning fine, i just cant controll it in webcontroll.
@Snippy said in Changing fan out from out9 to out5 has no effect:
yes that is because of your wiring
@Veti said in Changing fan out from out9 to out5 has no effect:
We all assume we know which part of our work is correct, so let's try to remain helpful.
Because LORD KNOWS I've been wrong so many times on forums where I'm asking for help I should get spanked.
that is why i asked for a picture so i can be sure that his wiring is incorrect
@alankilian said in Changing fan out from out9 to out5 has no effect:
your fan going to (BLACK)-> OUT5 and (RED) to V_OUTLC1
Try this and see if it works for you.
@alankilian Still running at 100% cant controll it from webcontroll.
And i cant run it from Out7-9 since fans in Out8-9 are 24v.
@Veti it is correct...
Got it to work, now the broblem is that the fans stop spinning at 70% in webcontroll, full blast at 100% and about 50% speed when set to 94% in webcontroll.
Got it to work,
so what was wrong?
try adjusting the frequency q.
try 10 , 50, 5000 25000
@Veti no idea, did the old ''have you tried turning it on and off again'' for about 5 times and told the printer i will build a new one so i think the tea and bisquits chip in the duet started to listen.
yes 10 was good,
Now all i need to do is design and simulate the cooling pipes.
Thanks for the help.
I'm glad you got it worked out.
These duet boards are great if you dont haveto touch the settings, it seems to allways open a can of worms that requires a sacrifice or two to appease the great one.
